block # 10243880
Old 11-10-2010, 12:27 AM
Adrenaline91RS's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 9-bolt Limited Slip
block # 10243880
My block number is 10243880, its a create motor from jegs... anyclue wat pistons are in it & there ratio,... would like to put a new top end on motor but got to figure out wats all on it now..
Old 11-10-2010, 06:36 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: block # 10243880
Originally Posted by Adrenaline91RS
My block number is 10243880, its a create motor from jegs... anyclue wat pistons are in it & there ratio,....
10243880 is a '96 -'00 350 Vortec block
http://www.jegs.com/i/GM-Performance...ductId=1231165
Old 11-11-2010, 12:33 AM
believe that is a similar motor but when i bought the car i was told the motor was no longer on jegs which was the end of 2008. ill figure out the number on the heads & wat rockers it has to help determine any more
Old 11-11-2010, 06:56 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Is the base Vortex 330Hp engine available anywhere all across the country
The same block # was used for other GMPP engines like the ZZ4 ( Alum heads ) and 383HT
Old 11-11-2010, 09:30 PM
so i would i determine the compression ratio of the pistons?
Old 11-12-2010, 02:03 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If it still has the Vortec heads it came with as a crate engine the specs are in the Jegs link
sheachopper
07-31-2019 11:27 AM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
skinny z
10-05-2015 06:23 PM
92projectcamaro
09-29-2015 07:07 PM
dusterbd
09-29-2015 08:40 AM
Quick Reply: block # 10243880
