Effects of a bad MAP sensor on your motor ..
Old 11-06-2010, 02:46 PM
robersml's Avatar
Car: 84 Z28
Engine: 305 HO
Transmission: 700R4 I believe, but not sure
Well, My computer is throwing code 15 and 34.
15: Low temperature indicated at engine coolant temp sensor
34: Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
I just put in a new 180 degree thermostat, though
So, what might cause the MAP sensor to trigger a code? It being bad or just, like the code says, high amounts of vacuum?
If the MAP sensor is bad, what kind of effect would it have on MPG?
The reason Im asking is that Ive gotten 13 -14 MPG city and highway, all around, for the last two years. I used to get 15 city / 23 highway, then practically overnight, it went down to that. Such a drastic change.
If anybody knows what effects a bad MAP sensor would have on a car, that would sure help.
It's an 84-Z28, 4 BBL, Non-HP, 305, smog pump removed
9192camaro
16
02-03-2019 12:21 AM
91REDZ28VERT
08-18-2015 10:16 PM
onebadazzsrt
08-15-2015 07:00 AM
squiggy2
08-09-2015 09:30 PM
Quick Reply: Effects of a bad MAP sensor on your motor ..
