Which transmission line is inlet and which is outlet?
Old 10-20-2010, 09:34 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
I'm trying to figure out which line on the tranny, the top or bottom, is the inlet and outlet. I heard the bottom line on the radiator is the inlet and the top is the outlet. Is this the same for the tranny?
Old 10-20-2010, 09:54 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: Which transmission line is inlet and which is outlet?
The bottom line on tranny is pressure feed out to bottom of radiator. The top tranny line is return feed from radiator
Old 10-21-2010, 11:43 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
To add to the question....does it really matter if you hook the pressure feed to the bottom or top of the radiator?
Old 10-21-2010, 11:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
The cooler is filled from the bottom to prevent aeration.
Old 10-21-2010, 12:47 PM
da.slyboy's Avatar
I knew there had to be a reason, thanks.
Old 10-26-2010, 07:08 PM
mikeirocz1's Avatar
Im going to run the fluid thru the radiator and the aftermarket cooler. So I need to come out the bottom of the tranny to the bottom of the radiator, out the top of the radiator, to the bottom of the cooler, out the top of the cooler, back to the top side of the tranny?
Old 10-26-2010, 08:44 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
You got it.
Old 10-26-2010, 08:56 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
For what it's worth, I think running to an air-liquid cooler is more efficient that to a liquid-liquid coller. Therefore, I'd run to the aftermarket cooler first. this is especially true if you place it in nearly unobstructed air stream. However, both will work.
Old 10-26-2010, 09:20 PM
Apeiron's Avatar
Engine: 383 Carb
Personally, I tend to subscibe to the idea that the ideal transmission fluid temperature is should be close to normal engine coolant temperature, so I'd put the auxilliary cooler first.
Old 10-27-2010, 07:56 PM
mikeirocz1's Avatar
The cooler is a derale cooler with a fan and 180 degree thermostat. Does it make a difference having the fan on the cooler on which one to go through first?
Old 10-27-2010, 09:25 PM
Apeiron's Avatar
Engine: 383 Carb
I doubt it.
AussiePr0nCar
03-06-2020 04:04 PM
MintWS6FORMULA
10-19-2015 08:53 PM
Reddeath210
10-06-2015 08:20 AM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: Which transmission line is inlet and which is outlet?
