Lt1 heads and intake on l98
Old 10-13-2010, 12:59 AM
smoor154's Avatar
I'm buyng a A lt1 intake with injectors, trottle body, and aluminum heads, I want to put all this on my 87 l98 motor, I know o need to modify the dizzy in rear what else sill I need for this swap thanks
Old 10-13-2010, 07:48 AM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
Re: Lt1 heads and intake on l98
sorry. Wrong answer.
Old 10-13-2010, 08:23 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I don't know all the specifics, but you will need to figure out how you're going to make a distributor work on the LT1 intake (been done, not sure whats involved) because the LT1 uses Optispark.
Not really sure there is a huge power advantage here - I mean, obviously some, but worth the effort for a minimal gain... i dunno.
Old 01-18-2011, 01:30 PM
JeffK's Avatar
Aren't there some differences in the water passages?
Old 01-18-2011, 04:24 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
you have to drill the hole and add a 5* distributer spacer... its angled at 5* towards the driver side..
the heads, there have been a few posts and pictures, but you need to modify the heads a great deal because they use reverse cooling, you need to weld up part of the coolant passage on the bottom, and drill a large hole in one side and add a tube either epoxy'd or welded in... i forgot the name of the guy who did it, but he had pictures of the process and how.. not something a rookie should under take at all
BUT.. if you want to take the short cut... there is a guy selling the intake and heads already converted in the "engine and performance" for sale section board.. he wants $1,000 for intake and heads... not a bad deal if you take into consideration how much work is involved
Old 01-18-2011, 04:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Drill hole in LT1 intake , run reg dist
Opti not used because he is using '87 electronics
Old 01-18-2011, 04:28 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
yes but you need to make a distributer spacer and put it on a 5* angle, get this part wrong and you will chew up the dist. gear or cam.. or both
here is the listing for the already converted intake and heads i was talking about
https://www.thirdgen.org/forums/engi...orted-lt1.html
Old 01-18-2011, 04:32 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by KiLLJ0Y
you need to modify the heads a great deal. i forgot the name of the guy who did it, but he had pictures of the process and how.. not something a rookie should under take at all
Pics no longer up but swap details still there
https://www.thirdgen.org/forums/tpi/...eads-gen1.html
Old 01-18-2011, 05:09 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
https://www.thirdgen.org/forums/fabr...n-project.html
Currently on the back burner at the moment.
midge54
12-27-2019 04:14 PM
midge54
01-29-2017 07:00 PM
LT1Formula
20
11-14-2015 12:02 AM
sweet_87_iroc
09-25-2015 10:01 PM
TheExaminer
08-19-2015 10:07 PM
Quick Reply: Lt1 heads and intake on l98
