speedo electric to manual
Old 09-23-2010, 03:14 PM
gto109's Avatar
hello all i have an 86 trans am with an electric speedo. the trans is a 350 turbo out of a 72 chevelle. the trans has a manual speedo set up and the car is electric is there some way to fix this with out changeing the trans.
Old 09-23-2010, 03:37 PM
houstonvett's Avatar
Re: speedo electric to manual
Autometer makes a unit to convert a older cable driven speedo/tranny combo to all electric for use with their electic speedos. You would have to find out the pulse rate of the Trans Ams speedo and see if it matches up to the unit Autometer sells. I am sure Autometer can calibrate their aftermarket module to any pulse rate they want and can match whatever is needed to make your Bird's speedo preform right.
Old 09-23-2010, 03:39 PM
gto109's Avatar
thank you ill have to check into that
Old 09-23-2010, 03:49 PM
gto109's Avatar
called autometer they don't have what i need. said that there stuff it calibrated to the pulse of there gauges
Old 09-24-2010, 12:46 PM
Did you find out what the pulse rate is for your T/A yet? It might be a simple way of getting Autometers pulse rate converted over to the T/As. If not you might have to go with an Autometer electric speedo if you want to keep the TH 350. Another option is to upgrade to a 4L60E tranny in place of the 350 guy.
Old 09-24-2010, 11:56 PM
gto109's Avatar
How do you find out the pulse rate. Also how hard is it to change to autometer gauges.
Old 09-25-2010, 01:37 PM
I'm not sure of the size of the Bird's stock speedo bit it should be 3 3/8". Autometer makes there electric speedos in that size and 5" also. Do a search here in the Forum about aftermarket gauges and the install. I am using the Classic Chevy (Covan) aftermarket setup for mine. I just bought the blank setup allready drilled out and will put in my own C2 full sweep guys.
Old 09-26-2010, 11:57 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Check with dakota digital. They have products that can help you. Good luck!
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
codeysabatini
11-10-2015 04:07 PM
tommy z-28
10-06-2015 10:58 PM
TrevinE
09-14-2015 03:20 PM
Magman
09-12-2015 11:55 PM
Quick Reply: speedo electric to manual
