which front end,fenders, will fit onto a 1989 camaro rs convertible
Old 09-12-2010, 05:39 AM
hasty88-and-89's Avatar
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
i had my very first crash yesterday and smacked a telephone poll
i need to know which fenders or hoods,,,doors,,,or front ends will fit onto a 1989 rs camaro convertible
is it just other 1989 rs camaro's? or will any third gen fit?
just a question to save me money
ALSO GOING TO BE TRYING TO FIRST COLLISION AUTO REPAIR NEXT WEEKEND ANY TIPS?
Old 09-12-2010, 08:21 AM
Stephen's Avatar
Car: 87 GTA
Re: which front end,fenders, will fit onto a 1989 camaro rs convertible
82-92 Camaro fenders fit 82-92 Camaros & 82-92 Firebird fenders fit 82-92 Firebirds.
But the early rears can give you a little trouble mounting ground fx, so try for 86+ fenders.
All the Camaro doors will match and 86+ front ends will match.
Old 09-12-2010, 01:10 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
even the hoods
but ok il look for an 86 and up car should it be 86-89 or should it be 86-92
Old 09-12-2010, 01:41 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by hasty88-and-89
even the hoods
Yes. All 82-92 Camaro hoods fit all 82-92 Camaros & all 82-92 Firebird hoods fit all 82-92 Firebirds.
The years don't matter, only the presence, or lack of, ground fx matters. Even if the new fender doesn't have any? It only a matter of drilling holes & the ground fx will cover it all up anyways, so nobody will ever see the old holes.
Old 09-12-2010, 01:57 PM
jer4251's Avatar
Car: They all sit.
Engine: LB9,LB9, LS1, LT4, LT4
Transmission: T5, T5, 4L60, T56, T56
you'll want a 90 and older fender with the correct slots for the front ground effect. 91-92 is different. also, you will need to trim the end near the door and reweld the convertible bracket to the fender. you'll trim 6-8 inches of metal from the back half of the fender. hoods are all the same, any will do 82-92. doors are mostly the same, make sure you get a camaro door or you might have to drill holes to fit your ground effects correctly.
Old 09-12-2010, 02:59 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
i dont understand the part you are talking about the fender and convertible top also all i need is the front fenders hood and front end ALSO WHAT DO I HAVE TO DO IF I WANT THE 92 Z28 GROUND FX
Old 09-12-2010, 03:13 PM
jer4251's Avatar
Car: They all sit.
ive got a pair of new fenders at my dads house, for a pre 90 car. where they mount to the side ground effects about the RS emblems, the convertible has a boxed frame along the side of the car, which gets in the way of a normal fender, so they had to cut both front fenders and add brackets to them from asc, so you will need to remove the brackets from the old fenders, mark and cut the new fenders and put the brackets on the new fenders. as fas as the years of the fenders, the 1991-1992 fenders have 2 slots to mount the front fround effect, the 90 and older have 2 holes i believe, they will only fit to the correct ground effect. to put the new gfx on the car you'll need to get the 91-92 front fenders, and the 8 91-92 specific pieces for the kit. the front ground effect, the rockers and door pieces, rear 1/4 extentions and full rear bumper. can get costly for a good kit. or just do the front and sides but the rear wont look right. the convertible section should have all the info you need.
Old 09-12-2010, 07:33 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
does that go the same for the 88 iroc-z28
Old 09-12-2010, 07:43 PM
Stephen's Avatar
Car: 87 GTA
PLEASE reread!!
Old 09-17-2010, 04:28 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
i kno but about 4 years ago my dad had to replace his 88 iroc hood and he said that a 87 or 89 wouldent fit
Old 09-17-2010, 04:39 PM
jer4251's Avatar
Car: They all sit.
any iroc/Z28 hood is the same, 85-92 Z28's were all the same hood. if it has removable louvers or blisters it will fit any year
Old 09-17-2010, 04:43 PM
Stephen's Avatar
Car: 87 GTA
If he tried a Firebird hood, then no. If he used a Camaro hood, then there is no way to say this nicely....He did something wrong.
ALL 1982-1992 Camaro hoods will fit ALL 1982-1992 Camaros
And....
ALL 1982 Firebird hoods will fit ALL 1982-1992 Firebirds
NO 1982-1992 1982-1992 Camaro hood will fit a 1982-1992 Firebird & NO 1982-1992 Firebird hood will fit a 1982-1992 Camaro.
Old 09-17-2010, 06:59 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
understood that
last question is
does a not z28 hood go onto a z28
understood u said all pieces
just confused
and if i get a non convertible third gen camaro front fenders
do they go onto a convertible camaro third gen
or was that the cut jer4251 referred 2?
Old 09-17-2010, 11:11 PM
3rdgenfever's Avatar
Car: 89 IROC-Z & 92 RS
Engine: 350 TPI & LQ4 408 in the works
Transmission: 700R4 & T-56
Axle/Gears: stock/ LT1 disc 3.42
a non Z28 hood will fit on a z28. the appearance is the only difference. Yes a non convert. fender will fit on a convert. ground effect mounting just wont be on the fender. make it fit dont know what else to say.
Old 09-18-2010, 06:08 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
a berlinetta doesent make any exception does it?
Old 09-19-2010, 02:27 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
kinda get why no one has replied but i just want to make sure before i spend money on an 82 berlinetta that the fenders match like the rest of the camaro's
Old 09-19-2010, 06:17 PM
go for it i hope they aren't charging you too much?? the only thing you will have to figure out is ground efx mounting. shouldn't be that hard.
Old 09-23-2010, 10:46 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Like said above if you get fenders off a non vert car they will need to be cut to clear the braces that were installed by asc.An 82 Berlinetta hood will fit without a problem
Old 09-23-2010, 11:15 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Third Gen Ranch just had some convertible fenders I believe.
Old 09-25-2010, 04:25 AM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
im
getting the car for 300 its non op 1 owner fresh interior rear end collision but back window is all good stil and its stil runs.
Old 09-25-2010, 11:43 AM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
The later hoods fit better then the earlier one IMO.
In other words, the front trailing edge on the '88 and up hoods is sharper and fits better then the earlier hoods with less gap on the front bumper.
customblackbird
08-15-2021 10:16 PM
Terrell351
06-13-2021 01:13 PM
84z96L31vortec
08-20-2017 12:16 AM
bellez77
09-05-2015 08:39 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: which front end,fenders, will fit onto a 1989 camaro rs convertible
