Speedometer reads too high
Old 09-02-2010, 11:27 AM
rallyup91's Avatar
Car: 1991 Camaro RS
Engine: 350 H.O. (330hp/400ft.-lbs)
Axle/Gears: 3.73 limited slip
I recently installed a 3.73 posi rear-end in my 1991 Camaro RS, and now my speedometer reads about 10mph to high. Any ideas as to how I can fix this?
Old 09-02-2010, 11:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer reads to high
Welcome to TGO. You'll have to swap the drive and/or driven gears in the trans. Check the stickies in the Transmission and Drivetrain forum.
JamesC
Old 09-02-2010, 11:39 AM
rallyup91's Avatar
Car: 1991 Camaro RS
Ok will do! Thanks for the help JamesC!
Old 09-02-2010, 12:12 PM
sharkbait's Avatar
Car: 1975 Novamaro
Engine: 1988 305 TPI
http://www.bgsoflex.com/speedo1.html
This might help
Old 09-02-2010, 12:22 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Actually his car being a 91 should be an electric speedometer. Atleast my 91 was factory. The computer would have to be reprogrammed for the calibration.
Old 09-02-2010, 12:50 PM
JamesC's Avatar
82-89 Camaro speedos are mechanical and have the VSS located on the backside of the cluster; 90-92 Camaros are electric and have the VSS located on the transmission tail shaft. The drive/driven gears are similar, but apparently not interchangeable between the two. With the correct gear(s) in place, the speedo should read correctly.
JamesC
Old 09-02-2010, 07:42 PM
rallyup91's Avatar
Car: 1991 Camaro RS
Thanks for the help! I know what I have to get now to fix it.
Old 09-03-2010, 08:59 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I replaced the drive and driven gear, which was a mistake in hind sight. I had to beat the drive gear off, and broke the replacement, requiring an other one. The dealership told me I need the combination. Just replace the driven gear with the correct one.
Old 09-04-2010, 02:48 PM
rallyup91's Avatar
Car: 1991 Camaro RS
Wow, talk about a headache! Thanks for the heads up!
toones
01-06-2016 06:00 PM
AUZ28
10-12-2015 08:40 AM
LittleFranks
09-17-2015 12:22 PM
AUZ28
08-26-2015 06:08 PM
AUZ28
Interior Parts Wanted
08-25-2015 07:29 AM
Quick Reply: Speedometer reads too high
