1988 Shifter Knob Removal?
Old 08-30-2010, 10:21 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
1988 Shifter **** Removal?
I have the stock shifter ****, its the funny looking one, not the ball. The car is an automatic. Can someone tell me how to remove that and to put like a different one on, like from pepboys, but it has that button in the middle, how do i bypass that? and does anyone know how I can just put a "T-Handle" **** on? like from a hurst shifter onto the stock shifter stem????? Thank you
Old 08-30-2010, 10:27 PM
Stephen's Avatar
Car: 87 GTA
Re: 1988 Shifter **** Removal?
With the engine off, put the shifter into 1st gear. If you feel the front down low, on the ****, you'll feel a slot. Inside tat slot is a U-shaped clip. Pull that out, need small needle nose pliers or tweezers (but probably too tight for tweezers) to pull it out. **** slides up & off after the clip is out.
TheExaminer
09-06-2015 11:40 PM
RyanJB
09-02-2015 01:27 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
Night rider327
09-02-2015 04:18 AM
Night rider327
09-02-2015 04:17 AM
Quick Reply: 1988 Shifter Knob Removal?
