1992 Firebird 305 TBI hesitation/surging while accelerating slowly??
Old 08-13-2010, 07:30 AM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
Ok I have a 1992 firebird with a 305 tbi, the car has 175,000 miles and I've noticed that my car has a slight surging feeli to it while slowly accelerating, I changed the TPS but still does this what could this be?
Old 08-13-2010, 08:10 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: 1992 Firebird 305 TBI hesitation/surging while accelerating slowly??
1. Check for codes, never replace anything without knowing its really faulty.
2. Setup a fuel pressure tester and see if fuel is the problem.
Old 08-13-2010, 08:58 AM
Engine: 5.0 TBI
I dont have a check engine light on, but do you think it could still throw a code?
Also what are some ways to check your fuel pressure?
Old 08-13-2010, 09:48 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Stock TBI system does not have FP test port. You can install inline FP gauge adapter available from several vendors:
<IMG>http://cfm-tech.com/images/product/tbiadapterandpsigauge_s.jpg</IMG>
Stock TBI system runs around 13PSI but I have seen engines run as low as 9 PSI. Anything less than 10-11 PSI you'll get stumbles and less than spirited performance. With miles that you have on you car it is likely that you have OE Fuel pump. Ninety percent of the time fuel pump is tired and output section hose connecting FP to the gas tank feed through is leaky.
Start with fuel pressure test....
//RF
Old 08-13-2010, 10:23 AM
Carlos773's Avatar
I purchased one from Autozone and its perfect, part number is CP7817. Its $50 but can save you the time and money of going around replacing parts that don't need to be replaced. Also yes it can throw codes without the light coming on, do the paper clip method and extract the codes and maybe that can shed some light on what might be going on.
Old 08-13-2010, 10:40 AM
Engine: 5.0 TBI
Ok I'll try that and see what happens
Glowsock
08-02-2020 07:36 PM
xkingcodex
02-12-2020 07:43 PM
MENINBLK
08-05-2015 11:58 PM
Quick Reply: 1992 Firebird 305 TBI hesitation/surging while accelerating slowly??
