New Fuse Box, What to remove? (89 Camaro)
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
which of the wires/connections should i remove?
the new fuse box will run ecm, fans, a/c, fuel pump, fuel injectors, mil lamp, coils, and has 12v switched, and 12v. it seems (key word) that i can just remove the box but i want some confirmation on it.
i only want to keep the stereo, lights, and heat and whtever is needed. im trying to see if A) someone has a diagram of what interior fuse box wires go where , and B) if the internal box can be removed with what ive listed for the new fuse box.
the only diagram ive found shows a couple things, not the entire fusebox.
im also changing the firewall connector to a caspers 32 pin connector.
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: New Fuse Box, What to remove? (89 Camaro)
Need to know what fuse box you're talking about.
Ghettobird52
12-29-2023 08:23 AM
backtothe80s
09-05-2015 12:39 AM
