Bent Pushrod, Is lifter bad also?
Old 08-04-2010, 07:02 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just tore my motor apart looking to solve a knocking noise that the motor was making. I found that it had a bent pushrod. However, after reassembling the motor the noise is still there. Could a bad lifter be causing my noise? Or maybe a bad cam lobe?
Old 08-04-2010, 07:47 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Bent Pushrod, Is lifter bad also?
How did the pushrod get bent? If it wasn't allowed to push the valve open normally because the valve hit something like a piston and stopped it, perhaps that is how it happened. If so, the valve probably has a problem now. Or the valve guide, etc.
Old 08-05-2010, 06:15 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I don't know how it got bent. I just found that it was bent when I took the motor apart.
Old 08-05-2010, 10:47 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Factory push rods are not very strong. A binding rocker arm or worn and binding valve guide may have caused the bent push rod. These push rods get softer with heat also. Verify the valve is good with a compression test, and if compression is low, a cylinder leakage test. If the valve is okay, inspect the lifter and cam lobe. Your 85 uses a flat tappet cam. The lobe may be flattened.
Old 08-05-2010, 11:52 AM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
what setup do you have is it stock? What ratio rocker arms? guide plates? what springs if not stock? what cam? what noise are you refering too? while it's true that factory pushrods are not relativly very strong you can still pick up the motor with a pair of them and not bend them. It usually takes quite a bit to bend one they don't just decide to wake up one morning and fold over something got bound up, or came to a sudden stop somewhere you just need to find it. Worn off cam lobes don't make noise it's completely silent when one goes. I'd say the problem exists in the heads.
~Couch
Old 08-05-2010, 05:37 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
There is a knocking noise coming from inside the motor. It has a comp cams camshaft in it (specs in sig) and it has comp lifters and springs as well. The heads are stock, stock 1.5 rockers, and no guide plates. I got a new lifter for it, should I go back in again and change it?
Old 08-05-2010, 05:58 PM
NAASBC355's Avatar
Car: several
Are you sure it's a lifter and not a worn out exhaust valve guide? Listen to the motor through a rubber hose and it will take you right too the source.
~Couch
dbrochard
10-03-2015 12:43 PM
dbrochard
09-07-2015 09:41 AM
Stryker412
09-07-2015 09:11 AM
dimented24x7
09-06-2015 03:51 PM
z28guy134
09-01-2015 11:50 PM
Quick Reply: Bent Pushrod, Is lifter bad also?
