Broken Bell Housing Need Help
Car: 1989 Pontiac GTA
Engine: 5.7 TPI L98
Transmission: 700 R4
Axle/Gears: Not Sure
i am putting a 35- tpi and 700r4 back in my 89 GTA. As i was bolting the tranny back to the motor i broke one of the bolt holes off the bell housing. Any ideas on how to fix this or should i just bite the bullet and buy a new one?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Broken Bell Housing Need Help
if you broke the bolt mount off, sounds like you are pulling the trans together with the bolts and something is binding up, torque converted not in all the way ect.
you may be able to have the tab welded back on. If you cant, you need a different trans, since the bellhousing is part of the trans and not removable
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
did you spin the converter to engage the notches in the front pump? it does sound like you are binding
Car: 1986 IROC
Engine: 355" TPI
You may be able to have someone weld it back on. If that does not work out you need a new one unless you want to try running without that bolt.
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
I have used JB weld to reapply broken ears before with good success. If you were cranking on the bolts to bring the two together hard enough to break the ear off of the trans. The front pump on the trans is probably junk. The front pump on the trans does not like having the converter being smashed into it. Good Luck.
Engine: 5.7 TPI L98
Its a cast bell housing wont welding it just melt it? I think i will just get another one just rebuilt the motor dont want to take a chance of screwing it up by taking a chance. Thanks for the ideas and the help.
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
na u just need a good welder, and some one who knows what there doing. its actally pretty easy. try jb weld first since its just a ear. if it cracks just take it to a machine/fab shop and have it welded on. ive welded a few, and also toasted a few.
no green
01-09-2016 09:22 PM
700r4, back, bellhouseing, bellhousing, broke, broken, crack, ear, fix, jb, repair, t56, transmission, weld, welding
