Quadrajet not idling ? New to this thing
Old 07-11-2010, 09:11 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
Just swapped my tpi to carb. I just took this carb off a motor that was running great. Bolted it on my motor and it wont idle at all. I can barly tap the throttle and it will run then die after 1 second unless I tap it again. It seems like its running out of fuel I think?
Everything I searched for looks really hard to read and complicated.
When I rev the motor it does great, but as soon as i let completly off the gas it stalls then dies.
I havent been able to set my timing yet so i dont know what its set at.
thanks
Old 07-11-2010, 09:25 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Quadrajet not idling ? New to this thing
so you downgraded from TPI to Carb? What other things did you hex or swap out along with the Carb?
Old 07-11-2010, 09:32 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Make sure there aren't any vacuum leaks.
Old 07-11-2010, 09:41 PM
wannafbody's Avatar
Car: 88 GTA
swapped to a thumper 279 cam, and put on headman long tubes..
i didnt downgrade IMO...
And id like to check for vacume leaks but it wont run long enough for me to spary around the intake.
Old 07-11-2010, 09:49 PM
Scorpner's Avatar
Engine: V6, V8
You could remove all but the necessary vacuum lines to make sure it's not an issue and then go from there. I know when I used all new vacuum lines on mine they didn't seal very well. I had to buy all new hose from a different store. Also check the carb and manifold to make sure there aren't any open ports.
Old 07-11-2010, 09:51 PM
wannafbody's Avatar
Car: 88 GTA
thanks Ill check that tomarow, I used the old 1/4" thick gasket witch seems to be good but Ill check it anyways, I might use some silicone too.
Old 07-12-2010, 12:31 AM
DoubleV's Avatar
Is this carb set up properly for your engine combo? You can't just take any old carb and slap it on any ol' engine and expect it to work properly. You need the right jetting for one.
So what kind of carb ( year, make, jetting etc ) are you using? What are the idle mixture screws set at?
Old 07-12-2010, 05:18 AM
wannafbody's Avatar
Car: 88 GTA
Its off a 79 truck, its not electric or computer controlled.
I have no Idea what anything is set at. All I know is that 3 days ago it worked fine, but it was on a differnt motor.
Old 07-12-2010, 09:58 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The cam in a '79 truck is vastly different from a Thumper 279.
The whole point of the Thumper cams is producing an engine that won't idle.
Old 07-12-2010, 03:14 PM
wannafbody's Avatar
Car: 88 GTA
lol.... its obviously not getting fuel at idle.. or not enough.. I can move the accelerater pump just enough to keep squrting fuel and it will keep running..
Old 07-12-2010, 03:38 PM
DoubleV's Avatar
Have you tried just turning the idle speed up and/or richening the idle mixture? If your engine wants more fuel, then just give it more fuel. You really need to properly tune the carb to match your engine. An untouched smogger truck carb on a big cammed motor is just not ideal.
I'd first start by rreplacing the Thumper cam with one that'll give you a better idle, more fuel economy, AND more power.
Old 07-12-2010, 03:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Get the Doug Roe rochester qjet carb book, he desngined them for GM and its the qjet bible to make them work how they should and not how the EPA wanted them to work.
nothing beats a well tuned qjet.......
Old 07-12-2010, 04:08 PM
wannafbody's Avatar
Car: 88 GTA
I turned the idle mixture screws all the way out and the idle screw is all the way in. It will barly idle like this.
If I put my hand over the top of the carb and restric the airflow it idles WAAAAY up. Is there anyway to make this thing get more fuel?!? Im gonna go try and turn my pressure up.
ALso when driving it down the road it will run good from about 2500 to around 3500 then it will sputter. then it will REALLY MOVE from around 4000 to about 6000... :-)
from 4000+ this thing fells like if I had the tpi on it still and just hit a 100shot of Nitrous!
Old 07-12-2010, 04:10 PM
wannafbody's Avatar
Car: 88 GTA
Also Im still running open headers right now.. How much would it help when I get the exhaust put on? I dont know if it makes much differance or not.
Old 07-12-2010, 04:46 PM
King NothingSS's Avatar
Car: 2001 Camaro SS
Engine: no engine yet :)
Transmission: T-56 with z06 drive gears
Axle/Gears: most likely 12 bolt or 9" with 3.91
well it wont be as loud when you get the rest of the exhaust on . . . and i'm still tryin to figure out why you downgraded from a TPI to a carb but to each their own.
btw you should've looked for a t-5 or t-56 trans to control that idle, do you have a stall yet for that thing? stock stall speed wont work for a bigger cam compared to stock size . . . i'm assuming it's the same with the stall in 3rd gens like it is with the stalls in 4th gens
Old 07-12-2010, 04:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
On the same hand TBI is just for those to cheap to go MPFI
Old 07-12-2010, 04:52 PM
Car: 2001 Camaro SS
why not just pull the engine and drop in a LS1? lol
Old 07-12-2010, 05:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Cause Buicks rule n Chebys drool
All my V8s are TriSheild's
See how screwed up I am ehy???
Old 07-12-2010, 05:19 PM
Car: 2001 Camaro SS
eh it happens lol
Old 07-12-2010, 05:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
eh it happens lol
BOP be Original
Old 07-12-2010, 08:31 PM
wannafbody's Avatar
Car: 88 GTA
looks like I need a holley
Old 07-13-2010, 04:13 AM
DoubleV's Avatar
No, you need to tune your current carb. Slapping on a Holley will not magically make everything better if you don't know how to tune a carb.
Did you check for vac leaks?
What are the specs to your cam and motor anyway?
Old 07-13-2010, 05:14 AM
wannafbody's Avatar
Car: 88 GTA
Stock tbi truck motor short block with tpi l98 heads. Running a castiron stock truck manifold right now with the stock 79 truck quadrajet.
Needs more fuel at idle.. I cant adjust the idle screws out anymore without them falling out.
No Vac leaks
Cam Style
Hydraulic flat tappetBasic Operating RPM Range2,000-5,800
Intake Duration at 050 inch Lift227
Exhaust Duration at 050 inch Lift
241Duration at 050 inch Lift227 int./241 exh.
Advertised Intake Duration279
Advertised Exhaust Duration297
Intake Valve Lift with Factory Rocker Arm Ratio0.479 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio0.465 in.
LSA(degrees)107Camshaft
Old 07-13-2010, 07:24 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
More fuel isn't the answer-how about LESS AIR?
CHECK FOR VACUUM LEAKS
SET TIMING
ADJUST CARB
Slapping on a Holley will not magically make everything better...or the rest of your motor fix itself.
Old 07-13-2010, 09:13 AM
Car: 2001 Camaro SS
i still think if you don't have a stall in there it's going to do the same thing, i had to foot brake my LS1 with a little 227/224 cam because the stock stall was too small
Old 07-13-2010, 09:32 AM
naf
naf's Avatar
I don't think stall speed is his issue yet. Of course, I'm assuming he's trying to get it to idle in Park or Neutral and I've been wrong before...
Old 07-13-2010, 09:40 AM
Car: 2001 Camaro SS
i've been wrong many times before lol hopefuly he's having a vacuum leak
Old 07-13-2010, 01:45 PM
DoubleV's Avatar
What's the compression ratio of a 'stock tbi truck motor with l98 heads'?
I'm sure tuning the carb will help alot in getting this thing to idle, but IMO that cam is really working against you here.
Old 07-13-2010, 07:56 PM
wannafbody's Avatar
Car: 88 GTA
I sprayed all around the intake and under the carb with brake cleaner to chek to leaks and I got nothing. The stall will need to be changed but I havent even put it in gear yet with it idling so thats not my problem at the moment.
The TBI motor with L98 heads should be exactly the same as a L98.
It has the same pistons anyways, only differance is no roller cam.
From everything I have found and read the Qjets run very lean at idle stock. So now I have much lower vacume and im sucking in alot more air and it seems like its just to lean to idle for more than about 2 or 3 seconds.
Old 07-13-2010, 11:21 PM
Car: 2001 Camaro SS
on my 2000 with that slightly larger cam and the stock stall, it would fall on it's face park . . . i'm still leaning towards the stall.
Old 07-14-2010, 06:53 AM
naf
naf's Avatar
Qjets run very lean when the idle mixture screws are turned in and many were set intentionally lean at the factory with tamper proof plugs over the screws. I 'assume' you've removed the tamper proof plugs?
Have you capped EVERY vacuum port on the carb and manifold, including the brake booster, etc.? Have you clocked the dist a little each way-or have a buddy turn it while you're keeping it running with the throttle?
Old 07-14-2010, 08:09 AM
1983Zsled's Avatar
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
A 1979 q-jet was an emmissions tuned carb. With the cam you are running you will need to enlarge the idle down tubes and the orifaces in the primary side that "sense" the air being pulled into the engine. Also the throttle shaft is probably worn out, allowing air to bypass the throttle plates. On a small cam you wont see much of a difference but on the engine you have now, I think you would notice. Buy a book called " cliff Ruggles" How to build and modify a rochester q-jet for performance" It is a great book that is easy to follow. I have a sbc with a mild summit K1103 cam. I had to rework my carb to get it to idle well. I have a wide band A/F monitor and it idles at 13.7:1 now. If you are going to keep the q-jet take the time to learn how they work and you'll be surprised at how easy, and inexpensive tuning them can be.
Old 07-14-2010, 08:44 AM
naf
naf's Avatar
All valid, but I would think he should be able to get it to idle, even if it's a rough idle without opening it up. It was reported to have worked perfectly on another, albeit less aggressive, motor. Even with the motor combo I'd think a rough idle at 800-1000 rpm should be possible with a "known good" qjet.
I'd get the motor running then open up the qjet to tune the quality of the idle. I fear the main prob here is outside the carb...
Old 07-14-2010, 08:28 PM
wannafbody's Avatar
Car: 88 GTA
Well I have checked and checked for vacume leaks, I cant find any at all..
This cam just doesnt have much vacum at idle and the carb isnt dumping enough fuel. If the car was only going dead when I put it in gear then I would deffinantly agree that the stall would be a big issue. The carb was running perfect on the stock cam and stock 76cc swirl port heads. I duno if I wanna mess with having to customize this carb or just save up for a holley.
If anyone has a good writeup on customizing these qjets (other than buying a book) with lots of pictures That would deffinantly help!
Thanks for all the input guys
Old 07-24-2010, 09:37 AM
wannafbody's Avatar
Car: 88 GTA
Update!!!
Found a nice used 650 double pumper.... Bolted her on... BAM!!! Idles like a drag car and runs like a scalded cat!
Screw quadrajet!
Old 07-24-2010, 12:03 PM
89 350 chicken's Avatar
Car: 1989 firebird
Engine: Carb Chevy 350
Transmission: turbo 350
Axle/Gears: 3.75
lol im only running a 550 cfm holly....been a while since i put the cam in...got a high rise edelbrock performance rpm intake and some headers mwahahah....i like it...need more...glad to hear you got a carb that works...i would of checked if the carb needed rebuilt...my holly blew the secondary circuits lol
Old 07-24-2010, 02:58 PM
DoubleV's Avatar
Screw quadrajet!
Glad your car's running good, but it wasn't the Qjet's fault it wasn't properly tuned for your application.
Old 07-24-2010, 09:52 PM
wannafbody's Avatar
Car: 88 GTA
Yea I know it was way off. I just couldnt find a way to adjust it without drilling and enlarging stuff.. I would have ****ed it up if i tried to do that. Atleast I can sell it now and get some of my money back. I got the holley for $150 so total I have about $600 in my whole motor and I know its pushing atleast 300hp. Ill probly add a 100 shot later after I get exhaust on it and a stall/shift kit.
Old 07-29-2010, 02:51 PM
1983Zsled's Avatar
Car: 1983 Z28
Infested
05-22-2018 11:56 PM
bamaboy0323
09-03-2015 06:07 AM
86IROC112
08-21-2015 07:20 PM
Bob88GTA
08-18-2015 03:31 PM
Quick Reply: Quadrajet not idling ? New to this thing
