IROC Wheels
Old 07-11-2010, 02:19 PM
matchbox's Avatar
Car: 87RS/70 novaSS/85 Z28
Engine: 2.8L/468 HP unknown/HO305
Transmission: 700r4,T400,stock
Axle/Gears: stock,fab9,stock
IROC Wheels
I have a set of iroc wheels and want to know why they are marked Front/Rear? I have a broken front and was gonna replace it with a rear one I have.
Old 07-11-2010, 02:25 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: IROC Wheels
I think its because there diffrent offsets or widths. but i think i remember reading you can put front iroc wheels on the back but not the back on the front. Good luck
Old 07-11-2010, 04:19 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: IROC Wheels
Not sure why this is under the engine section.
You are correct. The width is the same. It is the offset that is different. You can put front wheels on the back but not rear wheels on the front. If you put rear wheels on the front, the wheel will hit the caliper and wont move once bolted to the rotor. And this goes for the regular wheels as well. Not just the Iroc's.
Old 07-11-2010, 04:24 PM
Engine: 305TPI
Re: IROC Wheels
haha i just noticed it under tech/general engine lol. wait when you say regular wheels are you talking about ALL wheels or just thirdgen? i remember a friend said that they mixed matched their wheels when rotating. like front on back, back on front
Old 07-11-2010, 04:41 PM
built91Z28's Avatar
Re: IROC Wheels
I'm talking about third gen wheels. I know for a fact that atleast the regular 91-92 wheels are also marked back and front.
Old 07-12-2010, 12:53 PM
matchbox's Avatar
Re: IROC Wheels
Thats to funny I just noticed that I put it in the wrong area. My bad but yall responded lol. if I knew how to move it i would sorry. thanks for the input. gonna do some measuring let you know what i find out.
Old 07-12-2010, 02:25 PM
matchbox's Avatar
Re: IROC Wheels
Okay so here it is. The back space on the rear iroc wheels are 4 7/8 and fronts are 4 3/8 ,so I put in longer studs and 1/2" space fixed the problem. I did this to the front so now I can use the rear one up front for now.
BlueIroc-Z
06-09-2019 03:22 AM
kah992
08-19-2015 02:55 PM
mustangman65_79
08-11-2015 03:17 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: IROC Wheels
