How to add an auxiliary input on an original Delco unit ? SOLVED WITH DIAGRAM !
Old 07-03-2010, 08:12 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Hi guys,
I've finally found the original UU6 deck for my T/A. I want to add an auxiliary input like on those unit seen on eBay, but I want to do it myself. I don't want to hear about FM modulators and related.
Some of the steps are explained here but it's not very clear, it looks like a simple mod but it's a little hard to figure out how to wire up the input.
The cassette unit is plugged to the main unit with this connector:
Here's what each wire correspond to :
orange = right audio channel
blanc = left audio channel
rouge = +12V supply for the cassette unit
brown = select tape as input when shorted to +12V (red wire)
red/white = select radio as input when shorted to +12V (red wire)
The easiest would be to wire a 3.5 input to the orange and white wires with a ground somewhere. The problem is that each time you would want to plug your auxiliary device, you would have to insert a cassette or whatever non metallic thing so the unit thinks a cassette is inserted.
I don't want that, I want the signal coming from the input to replace the cassette (or radio maybe) signal when I insert a plug in.
I think I have to start with a switchable 3.5 input (5 pin), are these the same found on computer sound cards ?
Is there an electronics expert here that can explain everything for those who want to keep their original radio with a modern "touch".
Old 07-04-2010, 09:11 AM
clomkfly's Avatar
Car: 1982 Z28
Engine: Stock 305 4BBL - New QJet
Axle/Gears: Stock
Re: How to add an auxiliary input on an original Delco unit ?
im guessing a simple 3.5 extension cable would work...split n splice the two cables inside to the left and right channel wire...there has to be a way you can jump the 12 volt to the cassette input so that it is always on...try it out...not like youll short something major out! LOL
Old 07-04-2010, 11:17 AM
Salvo's Avatar
i would just wire the tape trigger to a micro toggle switch. Hide it someware under the dash
Old 07-04-2010, 12:41 PM
clomkfly's Avatar
Car: 1982 Z28
Axle/Gears: Stock
nice! that would work
Old 07-04-2010, 01:11 PM
DaveBerlinetta's Avatar
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
I've been looking into this since last fall for the radio in my '85 Berlinetta. It has the 'pod'-type radio.
I've been doing electronics repair for the last 25 years. Mostly computerized display systems for aircraft cockpits. Digital, analog, thru-hole and surface mount. I've worked with them all over the years.
The best way to do this is to solder an input jack to an unused input on the multiplexer chip, then force the control lines to use that input. I found that my Berlinetta radio uses a mux chip with four inputs. Only two are used (radio, cassette). I've searched for a 3.5mm jack that would allow me to just plug-and-go, but haven't found one yet. I found them in 1/4" jacks, but I think because of their size, they're not made in 3.5mm. So that leaves an external switch to choose inputs.
I've recently tested this using a Zune for audio input, and just forcing the radio to use it. See this post for more detail. https://www.thirdgen.org/forums/car-...o-rebuild.html
I haven't looked at the regular Delco radios in other Third-Gens, but I have to think they are similar. Does anybody have a schematic? If you can email them to me, I'll see if and where an aux input could be soldered to.
Old 07-05-2010, 04:28 PM
I just found this pdf : http://www.antechlabs.com/K0GFM/DelcoRadioMod.pdf
It's for even older AM Delco radios, but it explains how to wire the 3.5 input.
Old 07-06-2010, 05:04 AM
Engine: 5.0 LG4
That setup works, but it's for connecting a stereo input device to an old mono AM radio. It is using the same technique that the eBay guys are using. This was my first thought on how to do it, but I thought it would add too much noise to the signal from having to route the original low-level audio signal out of the box, thru a jack and then back in. Looking at the eBay setups, that is exactly what they're doing.
Old 07-12-2010, 07:09 AM
I've done it ! It works BUT the sound from the input is extremely low, I can barely hear a thing.
I've seen somewhere to add a 100k ohms resistor, if someone can guide me through this.
I will make a diagram to show everyone what I did.
Old 07-12-2010, 12:41 PM
After a lot of reading, it appears that the sound quality coming from the cassette deck is poor unless it reads a cassette. So I'm changing my plans.
The best way to do it would be to send the signal directly into the amp, to cut the radio signal.
The guys that sell those modified Delco radios are apparently doing it this way. Now we need to find out how they do it.
Now it gets a little more complicated.
This is what this guy did : http://www.youtube.com/watch?v=LdP-Knjuoi0
Old 07-14-2010, 06:59 AM
Yesterday I decided to rebuild my setup all over (still with the cassette wires). I used new components, new wires, and better solders. And it works pretty darn good now !
The sound quality is excellent, I'm really surprised. I've only used two trashed Blaupunkt speakers from the late seventies, but even with those the sound is great. The equalizer works like a charm.
I'm must have messed something up though as the tape player won't work at all.
I will make a diagram for those who are interested in adding an input.
It's really easy, this is all you need :
- wires of different colours (I got mine from a trashed Peugeot 405 wiring harness)
- DPDT switch (six poles, on/on)
- 5 poles switchable jack input (the same that you find on sound card and motherboards)
- soldering iron
- solder
- electrical tape
- heat shrinking tubing (not necessary but that is much better and cleaner than tape)
- a bit of patience and care
I already had the tools, I found the components on old computer stuff, so I haven't spent a dime on this.
There must be a way to use the jack as a switch but I haven't found out how.
Old 07-14-2010, 07:18 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
diagram and any pics you have would be awesome, thanks
Old 07-14-2010, 08:32 AM
Re: How to add an auxiliary input on an original Delco unit ? SOLVED !
Here's the diagram, hope it helps :
If any electronics expert has some recommendations, I'd love to hear them !
I listened to music for 50 minutes last night with the unit with no problem.
Old 04-17-2011, 10:54 PM
squibbles's Avatar
Car: 1985 firebird
Engine: v6
Transmission: turbo auto
Axle/Gears: ?hellifiknow?
Re: How to add an auxiliary input on an original Delco unit ? SOLVED WITH DIAGRAM !
ok ive fried my radio, not by incorrect wiring but because i think its old. i i pushed the volume control in tape mode and it smoked and fried my radio.
Old 10-26-2011, 02:40 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Numb this, I just finished doing it to my car
Old 10-26-2011, 08:31 PM
Octane's Avatar
Car: Still dreaming
http://www.google.com/products/catal...ed=0CHYQ8wIwAA
Old 10-26-2011, 08:39 PM
58mark's Avatar
I've used those... two problems with them...
first, they sound muddy, like a cassette... go figure
second, a 20 year old radio isn't likely to have the cassette desk in working order. some do, most don't
Old 10-27-2011, 02:08 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Mark, it doesn't use the (cassette player) itself; it uses the wires (power/left/rirgh channel) that go from the cassette player to the radio board harness. The cassette player is what goes bad; not whats leading out from it. the magnetic reader things give out.
trust me my cassette player doesnt work. it wont play my ***** nelson or kiss cassette but i did this yesterday morning with the parts i got from work. it works like a aftermarket head unit with a aux input. i can show you in person because your not far from me.
Old 10-27-2011, 02:10 PM
58mark's Avatar
Did you see the link in the post right above mine? I was replying to octane
Old 10-27-2011, 02:12 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
sure didnt, im on my jobs computer. im limited!
Old 10-27-2011, 02:13 PM
58mark's Avatar
Its one of those cassette adapters that needs a working deck for it to work
Old 10-27-2011, 02:26 PM
Octane's Avatar
Car: Still dreaming
For some people it could work, just a suggestion
Old 11-13-2011, 02:29 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
ive owned 4 third gens, a 95 cadillac with the delco unit, and an old cavalier. ALL of my tape decks worked perfect. my girl friend owns 2 camaros and had a firebird, al of her tape decks worked
Old 11-26-2011, 09:50 PM
dcil's Avatar
Could use the switching jack to trigger a micro relay to bridge the brown and red wires.
Old 11-26-2011, 09:54 PM
dcil's Avatar
Looks like I have a project to play with next week. Probably take the complete tape section out, make an abs plate to cover the hole and mount the jack. Heck, may just gut a cell phone charger and add a usb charge port.
Old 11-27-2011, 03:39 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
i just did that actually, i added a dual usb port on the plastice above my ac controlls.
sense i work at raadio shack, i took apart a 1.2 amp usb car charger, wired up a fuse amd did some plactic cutting,
Old 03-07-2015, 02:30 AM
jim.miller.bpi's Avatar
I'm no expert, and I know this is an old thread, but I just wanted to see if this makes sense to anyone else. From what I can see, you installed a system with this diagram and then the cassette player stopped working all together. It seems the reason is that you're cutting all power from the Casstette deck with this configuration. Because the cassette deck has it's own set of built in switches to determine the selected audio source, it would be a good idea to remove them from the mix when selecting an aux device to ensure that nothing has a chance to mess up the radio itself. Your configuration does that, but then never has a way to restore that back to the cassette deck. Here's how I would wire it. You'll need a 9 pole switch for it. The AUX input line would still connect like you have it but I think the switch should look like this picture
. I"M NOT A GRAPHIC ARTIST!!!!! I"M NOT EVEN CLOSE!!!! But, I think you can see where I was going with this. What it does, with the switch in the displayed left position, all circuits are broken other than the ones needed to select the "tape"source to activate the AUX input. In the right position, it establishes all of the connections as they were before modifying. This will them allow the Cassette deck to get power and also allow it to select which audio source to use. Please don't hesitate to let me know if anyone finds any errors in this. It's late and I'm just doing a little research about building an onboard computer for my truck.
Old 03-07-2015, 02:38 AM
Also, I have a question... being that you're removing the power from the cassette deck, this should also kill the EQ built into the cassette player that runs the whole radio. Is this correct? Does that radio in question have the built in EQ like mine does? If so, this could be a problem. If that's the case, then we would probably need to solder the leads from the AUX input right into the audio leads in the cassette deck and then use a 3 pole switch wired straight into the cassette deck to select between audio sources and FIND and REMOVE the switch as it exists in the cassette deck so that you will have to manually switch between devices rather than risk a short or over powering the 12vdc line going back to the main unit. If that happens, you'll get a smoking radio and just wind up having to replace it anyway.
Old 03-07-2015, 02:43 AM
But you'll also have to have something to BREAK the white and red wires, otherwise, the system will fault and both devices will be selected. I think this will kill the radio.
Old 03-12-2015, 05:12 PM
I actually haven't tried with a cassette...but it works perfectly with either the AUX or the radio, even though, being in Europe, most US channels won't work. If anyone knows how to use odd and even numbers channels, that would be great. I use the radio all the time when driving and I must set it to a high volume because of the various noises my T/A makes.
Old 04-24-2015, 09:22 AM
92RSCamaro1's Avatar
Car: 92 Camaro RS
So if I add an 3.5 AUX input to the radio, how does it switch over with adding a tape in the cassette player?
Old 06-01-2019, 11:15 AM
MarcusMandarino's Avatar
Car: 85 Camaro Berlinetta
Hello, Dave. I also have a 1985 Berlinetta like yours and I have some bad contact on my radio. Looking here in forums by schematic, I found your post. From what I understand you have the schematic of the Delco. Can you give me a copy? Thanks for your help in keeping our model working!
Old 06-01-2019, 11:36 AM
Engine: 5.0 LG4
Marcus,
I had the schematic for the Berlinetta 'Pod' radio, not the regular radio installed in the dash, you put this in a thread for regular Delco radios.
I say had, because I haven't looked at it for years, and I'm not sure if I have it anymore.
What exactly do you mean when you say you have a 'bad contact'?
Old 06-01-2019, 06:34 PM
Hi Dave,
First of all, thanks for the quick reply!
I have the Berlinetta "Pod" Radio... For some time he has problems in the audio, that goes back and forth, sometimes a channel, sometimes another. I already checked the connectors but I would like to have the schematic to follow the signal with Oscilloscope. If you can find it, or know of someone you may have, thank you very much. Sorry for bad English...
Old 06-02-2019, 10:07 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Speaker problems on 1 (or more) of the 4 channels is usually caused by a problem inside the Receiver. If your interested in obtaining a replacement Berlinetta Receiver WITH the AUX jack installed on a cable,..... it's $145 + shipping.
** Price in USD for the 84-85 style Berlinetta EQ Receiver with AUX.
Old 06-03-2019, 10:00 AM
Engine: 5.0 LG4
Originally Posted by MarcusMandarino
Hi Dave,
Marcus,
I'll try looking for the schematics. In the mean time... It sounds like you have access to a scope and know how to use it. Have you tried to just monitor the outputs from the amplifer box. That would eliminate the radio as the problem. Try to bypass the speaker wires by jumping a short cable from the box to a loose speaker. I've found that most of my audio problems are with the speaker wiring being intermittent. Body schematics are in back of the factory manual.
John from RI, would you be able to help Marcus with tracing the outputs inside the box?
Old 06-03-2019, 11:37 AM
Dave,
The problem seems to be in the preamp area. If I give a little hit on the receiver unit the sound will come back ... Turning it on and off too. Now the radio is mounted on the car (and you know how hard it is to take out ...) and I just want to take it out when I get the schematic. I have the technical skills to fix this. John suggested replacing the unit but it's a little tricky to do this because I'm in Brazil (customs & costs). So I'd rather wait for the possibility of getting the schematic.
Thanks,
Marcus
Old 06-03-2019, 01:05 PM
John in RI's Avatar
Marcus; I got your E-Mail but will reply here........
I do not have the radio schematics that you are looking for. Another member here 'hooked me up' with some radio schematics probably back around 2002 or so. A couple years later I mailed them to someone else after receiving a $50 deposit that was to be returned when the guy was done using the schematics and sent them back to me,..... then, I never heard back from him. 25-30 years ago when I was used to pay a repair shop to fix my Berlinetta cassette decks that repair tech would always do some additional work inside the Receivers I gave him to resolve/avoid speaker channel problems. I couldn't tell you what he did - just that the bad speaker channel problem is (usually) caused by a problem in the Receiver itself.
Shipping to Brazil = $73. I have NO IDEA about Brazil customs,............. it would be up to you to figure that out.
P.S. Only takes about 5 minutes to remove the entire radio from the console; why not pull it out, set it up on a bench, hook up power/ground + a couple speakers,... then start probing !?!?
Old 06-03-2019, 01:23 PM
Hi John,
Thank you for your feedback. The problem with customs is a bit more complicated ... I can not import used items. Although you could pay 60% on the FOB cost (item + freight). So I'll wait for a possible trip to the USA next September, and then I can bring it in my luggage. The price is $ 145, no core? In this case, I'll talk to you again. Until then I'll do what you said: get out of the car, setup it on a bench and try to locate the problem.
Thank you for your kindness!
Marcus
Old 06-03-2019, 01:41 PM
John in RI's Avatar
No Sweat Marcus !!
I know that all countries handle customs different and I'm not well versed on international customs practices of any country other than my own.
No; No core needed. Also; I don't normally install the AUX jack on a radio until someone requests that type of radio with the AUX. A LOT of guys simply want a stock replacement radio without any mods. If you *might* be interested in one of these Receivers with the AUX,........... just send me a message in advance of your trip to the US so I can have one prepared & ready to go for Ya'.
Old 06-03-2019, 04:17 PM
Engine: 5.0 LG4
Wow, has it been that long....?! Yeah, sorry to say that was me. That was a real busy time of my life, no excuse tho. I'll do what I can to find the schematics and get them back to you if you still want them. I'll also send you a suprise that I hope will make up for it a bit.
If you don't mind me asking, how are you hooking up your aux in cable and how do you keep the radio from playing over it?
Old 06-04-2019, 01:41 AM
John in RI's Avatar
Well,... maybe it was around 2004 ?!?!?! And maybe it was $40,... or was it $50 ?!?!? It's a small world,... ain't it Marcus !!
I'm a novice - maybe an amateur at this point - when it comes to radio repair. I had schematics available to me when I figured out the Berlinetta AUX that I no longer have access to. While I've shared just about everything I've ever learned about Thirdgens on this site and others,.. how to install the AUX on a Berlinetta head unit is going to be 1 secret that I keep to myself. I can only hope that you can relate.
Old 06-04-2019, 08:15 AM
Hi John!
I fully understand your point and I support it. I'm not looking for the AUX input ... I'm just trying to get the radio to work! So, I keep looking for the schematic. And, I'm still interested in a radio spare, so when I travel to US, I'll pick you up.
Thank you.
Marcus
Old 06-04-2019, 08:51 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Old 06-04-2019, 12:15 PM
John in RI's Avatar
The scary thing Steve,....... I remember reading this thread when it was new !!
Old 06-05-2019, 10:55 PM
Engine: 350 TPI L98
Transmission: WC T5
No fooling. Although many of us aren't super old yet, my Dad has a saying:
"Life is like a roll of toilet paper, it goes faster towards the end."
Old 06-06-2019, 09:57 AM
John in RI's Avatar
These days ( my youngest son gets is HS diploma tomorrow ) I feel the same way about myself as I do about Mean Green,............. Hard to believe, but this thing is an Antique !!
Old 06-06-2019, 10:14 AM
Engine: 350 TPI L98
Transmission: WC T5
Wow, congrats!!! Coming in for a smooth landing into the empty nest? My middle one graduates from HS next week. One more to go!
Old 06-07-2019, 01:05 AM
jczoka's Avatar
Car: 1991 Z28 5spd
Hi John!
Thank you.
Marcus
Check out this site. Some good info about the amplifier board repairs. It has some schematics of the amp board.
http://www.howtoalmanac.com/Scott/Ho...oAmpRepair.htm
Old 06-07-2019, 10:51 AM
Good info!
Old 06-07-2019, 12:54 PM
John in RI's Avatar
The schematic / images are for the regular 'Delco 2000' radio AMP circuit board but the Berlinetta head unit is a different beast altogether. I've got that link saved for "someday"........might try to modify a regular radio by adding the pre-amp outputs in the future to see how it works out. Not in a big hurry cause' I've got a BOSE system in everything I drive but I'll give it a try (someday !)
Quick Reply: How to add an auxiliary input on an original Delco unit ? SOLVED WITH DIAGRAM !
