GM A/C Compressor rebuild kits?
Old 06-07-2010, 06:16 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Does anyone know where I can get a rebuilt kit for the gm ac compressors? The only thing leaking on mine is the outer edge and I can't justify spending $150-$200 for a compressor if I can get a rebuild kit for all the seals, especially when my clutch is still good too.
thanks guys
Old 06-09-2010, 12:45 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: GM A/C Compressor rebuild kits?
I have a perfectly working compressor off my 91 formula. Let me know if you want to work something out.
Old 06-09-2010, 01:08 PM
mos68x's Avatar
When was the last time it was charged and used? Mine passed the vacuum test, but leaks around the outer edge seal on the compressor, but the clutch works fine. My problem is that it leaks when I put it under pressure for charging it.
Does yours have the low pressure switch on the top of the backside of the compressor?
Is it for R-12 or has it been converted for R-134a?
You have any pics of it??
Old 07-25-2010, 10:27 PM
mos68x's Avatar
Hey zach you still looking to get rid of that compressor?
italiano67
12-11-2016 09:21 AM
Magman
09-13-2015 08:43 AM
greenyone
09-02-2015 03:39 PM
SlowAZ28
08-31-2015 07:56 PM
someone972
08-30-2015 12:52 AM
Quick Reply: GM A/C Compressor rebuild kits?
