Shifter for 700R4
Old 06-07-2010, 09:05 AM
iroc_valencia's Avatar
Shifter for 700R4
I'm tired of the stock shifter in my Camaro , my trans it's a 700R4 , i'm looking for something aftermarket in the range of 100-180$ , anybody knows direct fit replacements (using stock center console) like this ?
http://www.summitracing.com/parts/BMM-80692/
suggestions ?
P.D. : I hate chrome parts
Old 06-07-2010, 12:10 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
Re: Shifter for 700R4
Console versions will work on camaros. It still requires cutting the tray plate and using the new overlay and shifter boot. On the Firebirds that have Formula style rolled ash tray they won't fit as easy. Theres not a lot of choices for direct fit under the consoles. Hurst makes a dual gate that has a console kit for them but there more expensive. I've also heard shifting is kinda awkward if you don't press it in the right direction you can still skip gears. I like my pro ratchet, but it's far from a direct replacement. I suguest searching around there are a bunch of pics of different ones. Any way you go be prepared to replace the transmission cable and adjust it. I used a the GM cable on the megashifter but it wasn't fun.
Either way you go you'll learn the "direct fit" parts are hardly ever direct fit.
Old 06-07-2010, 05:17 PM
Yeah, i've seen the hurst dual gate , it's fancy!!! , but i'm looking for a ratchet type.
I'll be searching pics.
Thanks for the tips!!
Old 06-07-2010, 09:53 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
Be nice if someone stickied unique replacement parts for camaro an firebirds. Such as the shifters. I know doing a search would work but something more direct and helpful than looking around for specific wording and looking through page fulls of threads and paragraphs full of articles in each one just to find what someone is looking for. Just an opinion.
Old 06-08-2010, 12:07 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
i really dont know of any other besides the bm megashifter. i will get one someday!
Old 06-08-2010, 01:46 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
If you don't like the chrome handle, you can buy a black plastic handle for pretty cheap that looks just like the chrome one. I have one, and the nice thing about it is it doesn't get so hot in the summer when I park my car in the sun that I can't shift out of park without burning my hand.
Old 06-08-2010, 02:00 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I run a B&M Megashifter. It works great with my custom built auto/manual 700R4. Install was pretty straightforward and it came ready to install in the 3rd gen. I also dont care much for the shift handle but I think I might just switch it to a shift ****. The lever is threaded.
Old 06-08-2010, 04:11 PM
bobbyvegas's Avatar
Car: 1992 Camaro Z28 Heritage Edition
Engine: 5.7 TPI (No mods)
Does this shifter show the 4th gear (OD)? I have only seen shifters with 1st, 2nd and Drive..
Old 06-08-2010, 04:17 PM
Engine: 383 SBC
Yes it should as most shifters will that are made for the 700-R4, which have the indicator. I know the proratchet also has a sticker to show the gear selection also, but it's not a console friendly shifter.
To get the indicator to work on the megashifter you must hook up the provided cable to the shifter and use there trim overlay and window. It's all included in the console version along with the 2 additional brackets needed to raise the shifter up from the sheetmetal tunnel.
Old 06-08-2010, 04:35 PM
Hheheheh , this is one of the reasons why i hate chrome parts , got more info about that black plastic handle ?
thanks
Old 06-08-2010, 04:37 PM
thanks
hmm , it's that ?
http://www.bmracing.com/PRODUCTS/Aut...-Black-Plastic
summit p/n : BMM-80642
http://www.summitracing.com/parts/BMM-80642/
thanks for the idea
Old 06-08-2010, 04:39 PM
Engine: 383 SBC
Believe so. I also agree on the megashifter getting hot in the sun. I've temporary branded myself before with the logo when I had one installed on hot summer days.
Old 06-09-2010, 12:16 AM
bobbyvegas's Avatar
Thanks for the info, it all makes sense
Old 06-09-2010, 07:16 AM
Now , collecting funds to get the shifter and the plastic handle.
*click**click*
Old 06-15-2010, 11:05 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Sorry for not getting back to this thread sooner. Yes the Megashifter works on the 700R4. It can se set up for 3 or 4 speed. And yes the crome handle does get hot in the sun. LOL. Fireturd put it best. Im all over that plastic handle.
Old 06-15-2010, 09:51 PM
tekkitan's Avatar
Car: 87 IROC-Z
I never knew there was a plastic black handle.
Old 06-15-2010, 10:34 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
I had the megashifter in my camaro for 5 years. I liked it. I drive with gloves on so I don't get burnt. Kept it for the TH-400/454 big block swap. Took it out for the T5 swap.
Old 06-16-2010, 04:42 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
thanks
A factory "T-handle" shifter from a 3rd gen trans am or 89 Z24 will work and cost less than $20.00
Best part is it will look factory
Old 06-26-2010, 11:44 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
I got my megashifter from a guy here on the calassified boards. It didnt have the front and rear mount brakets. It was still easy to mount it. B&M said that I didnt need them all I had to do was use/make spacers. It did come with 2 that he used. All I did was drill 2 holes and then ran carrage bolts with lock washers and a little lock tight. No problem.
ndndndnd
09-28-2015 08:00 AM
6998poncho
09-25-2015 02:56 PM
Quick Reply: Shifter for 700R4
