SBC oil pan options
Old 06-06-2010, 08:29 PM
skinny z's Avatar
SBC oil pan options
Who is running what for an oil pan?
I'm looking for stock k-member and LT headers application.
I've been checking out the Moroso drag pans with a built-in scraper and kick out as well as an integral windage tray.
I haven't seen or heard of anyone using one in a 3rd gen. Just curious as to whether it would fit.
Maybe there's something comparable on the market?
Old 06-06-2010, 11:08 PM
On Probation
Atilla the Fun's Avatar
Car: seeking '90.5-'92 'bird hardtop
Engine: several
Transmission: none
Axle/Gears: none
Re: SBC oil pan options
When I pushed my '88 IROC-Z 350 into the low 10s with a carb'd 355, I was using a stock '88 pan. I never hurt the bearings or anything. How quick are you running?
Old 06-07-2010, 06:36 AM
skinny z's Avatar
I'm not running low 10's that's for sure.
Not looking too either. At least not with this latest project.
I'm just looking to make improvements here and there.
Depending on which direction this next build goes, I'd like to participate in a few open road events. If I'm going to be at near 6000 rpm for extended periods of time (rather than a few seconds) I would think a little oil control would be a benefit.
Old 06-08-2010, 08:19 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
In that case, I'll see if there's anything promising in any of my Manufacturers' catalogs.
Old 06-09-2010, 06:54 AM
skinny z's Avatar
I had read an article demonstrating a Moroso pan with baffles, windage tray and crank scraper. I did a little searching but couldn't find it again. Nor was I able to find it on Moroso's web site. The difficult part will be determining whether it will fit a 3rd gen chassis.
Old 06-09-2010, 08:22 AM
TB2
TB2's Avatar
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
I have an ebay special peice of ****. It was suppose to be a road course pan that I had to modify it to fit the chassis. As soon as I had it on a road course and made a long right hander it was apparrent they sold me a circle track pan as I had no oil pressure. I changed the doors around on the inside to make it work. But I'm going to replace it this winter. Canton makes some nice road course pans. Moroso makes a street/strip pan just for 3rd gens that looks pretty good.
http://www.jegs.com/i/Moroso/710/201...91#moreDetails
Old 06-09-2010, 08:49 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Here ya go. Uses stock k member, has a baffle in it, great price. I paid $200 for mine. Wish I'd have gotten this one instead. Buy it and support another TGO member!!!
https://www.thirdgen.org/forums/engi...quart-oil.html
Old 06-10-2010, 07:06 AM
skinny z's Avatar
Still looking for the pan with the built -in scraper and top-side kickout.
Getting closer.
http://www.summitracing.com/parts/MOR-20191/
The one I'm after has a kick out near the pan rail and adjacent to the scraper. That kick out is what I believe will cause the interference in a 3rd gen chassis.
Found this on the Canton website (thanks TB2).
http://www.cantonracingproducts.com/...ion&key=15-010
Or better yet, this one.
http://www.cantonracingproducts.com/...ion&key=15-244
Old 06-10-2010, 08:25 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
still trying to out-trick yourself. If your block is pre-'86, use the Moroso 21804. If '80-'85, then 21807, and if '86-up, then 21808.
Old 06-10-2010, 09:01 AM
skinny z's Avatar
[QUOTE=Atilla the Fun;4574284 If your block is pre-'86, use the Moroso 21804. [/QUOTE]
It has the features I'm looking for however.....don't circle track specific pans have their trap doors oriented in such a way that left hand turns keep oil in the sump but right hand turns result in the opposite? There was a posting here that alluded to such a situation.
Old 06-10-2010, 10:32 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you're not running an HV pump, this should do well. Notice the built-in full width windage tray. I don't think these have the trap doors in them. Also, in road racing, each turn only lasts about a third as much length as on a big oval, and each left is followed by a right, and vice versa. If you're still not comfortable with it, then don't try it. But I'm comfortable with it.
gixxer92
09-01-2015 04:32 PM
downsouthboy
08-29-2015 11:29 AM
Navy8125
08-21-2015 09:32 AM
Dialed_In
08-20-2015 01:45 PM
MY87LT
08-17-2015 08:43 AM
Quick Reply: SBC oil pan options
