Firebird Dash fitment for Camaros?
Old 05-28-2010, 09:41 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Simple question, Will it fit? I know the Camaro dashes have the lump/insert in the middle for the heater/ac. What other differences are there?
I have a chance at a amazing dash from a 91 Firebird and I am planning to buy and resell for a profit but started wondering if it can fit or be made to fit into my Camaro.
Thanks,
Carlos
Old 06-06-2010, 05:49 PM
qcworm's Avatar
Car: 1987 IROC Z-28
Engine: L-B9
Transmission: 700R-4
Re: Firebird Dash fitment for Camaros?
no it will not fit, i made the mistake of buying one thinking it would fit, they look the same but the distance from the windshield to the leading edge of the dash is about 2 inches different, so dont wast your time
Old 06-06-2010, 11:33 PM
Former Sponsor
Thirdgen Ranch's Avatar
Car: Too many
Nope, they're not even close. The depth is different and the mounting holes are in different places. Unfortunately, lots of people buy Firebird dashpads instead thinking they will work because they cost about half as much as a Camaro pad.
Old 06-08-2010, 02:49 AM
85Z28NOS's Avatar
Car: 85 Camaro & 84 Fiero
Engine: 350 HSR
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Are we talking about the dashpad or the hole dashboard? The dashpads are completely different, but the entire dashboard can and will fit into a camaro! Want pictures of a 88 digital dash from a GTA in a 85 Camaro? I do recamend if you install a firebird dash into a camaro that you also install the center console. For thew price of a good condition camaro dashpad you can buy all the firebird stuff. Your chioce, hope this helped
Old 06-08-2010, 03:09 AM
Carlos773's Avatar
Dashpad, I picked it up for almost nothing well $5 from a 1991 firebird, Dash is completely perfect. I figured eh wonder what are the differences so I asked here before picking it up and found out too. Well either way a friend of mine is picking up a Firebird for himself soon, and most likely its pad is gone, so this will make a good present for him.
Old 08-04-2010, 06:54 AM
nolmtD2's Avatar
Car: 1992 Camaro RS
so just to clearify, you can use a firebird dash with a camaro dash pad, right?
Old 08-04-2010, 08:29 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
no. dash pads are not interchangeable between camaros and firebirds.
Old 08-12-2010, 07:53 PM
Pairof91rss's Avatar
Car: 1991 B4C-1991 RS
Engine: L98 5.7 TPI-LB9 5.0 TB
I would love to see a firebird dash setup in a Camaro...I like the guage looks in firebirds that Ive seen.
Old 07-23-2012, 03:09 PM
mich2112's Avatar
Car: 1991 Z28
Engine: 350 L98
Axle/Gears: G92 - 3.23
OK...so why are the Bird dashes so much cheaper?
Old 07-23-2012, 06:06 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
because in my personal experience firebird dash pads tend to resist cracking for some gay reason
Old 07-23-2012, 08:51 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
It's probably because they're shorter from the windshield to the edge.
Old 07-23-2012, 09:26 PM
82tarecaro's Avatar
Camaros have that funky speaker grill that likes to crack.
Old 07-26-2012, 04:31 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Here's the deal... If you cut the top 2/3 of the Camaro dash side brackets off and do some hammering to bend the rest properly, the Bird dash fits just fine. How do I know? My 87 Bird's dash shell is currently in the IROC (trying to get it driveable before I go full-out on the 4th gen stuff). It's only a shell for now as I ran out of electrical tape rebuilding the harness (had cut some stuff out to keep for the 4th gen dash but had to put it back). Keep in mind that everything EXCEPT those side brackets is identical between the 2 cars. The Bird only has 2 lower corner brackets mounted about a 1/4" lower than the full-height Camaro brackets. As the guy said above, with modifications to the existing brackets, it WILL fit.
As to why? Personally, the big empty space on the passenger's side is bad enough on a Bird dash, which has that stinking dash pocket, but the Camaro has nothing there. And the Camaro also has that big wide open space under the center vents the Bird doesn't have, which also looks like crap, IMHO. For why I did it? As I said above, it's a go-between until I get the 4th gen parts, and the side brackets had to be modified anyways for the later dash, so why not? And I didn't have a dash for the 88, period. PO (not the guy I bought it from, the guy who has serious issues and stripped things here there and everywhere out of it) stripped it out except for the lower support bar, which is hanging in my garage.
Long story short, yes it does fit. But you need to cut the side brackets and bend them to make it work.
Old 01-24-2020, 06:11 PM
skyarme's Avatar
Car: 1991 Camaro Z28
Engine: 5.0
Transmission: Automatic
is their any way you can send some pictures of what you did because I just realized I bought a bird dash and I want to put it into my 91 z28
Jorlain
08-24-2022 05:11 PM
Vintageracer
01-10-2020 05:33 PM
The_Phoenix
02-04-2016 07:10 AM
kah992
08-19-2015 02:55 PM
Vintageracer
08-11-2015 08:13 PM
Quick Reply: Firebird Dash fitment for Camaros?
