Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Weight Loss Program
Old 05-20-2010, 12:37 AM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Weight Loss Program
I just had my Firebird weighed on all 4 corners, and its not as light as the "slide scales" at the track said it was.
3300lbs w/ a 210 lb driver. There was a difference of about 200lbs difference between the R/R & the L/R. With a full turn of the R/R adjustable sway link, the weight on the rear equaled out w/ me in it.
Soon to be removing the front & rear bumpers, & front & rear glass. I cant part w/ my power windows yet.
Old 05-20-2010, 07:12 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Weight Loss Program
So it is 3090 lbs? Not bad man.
Old 05-20-2010, 11:07 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
3455lbs with me in.
Old 05-20-2010, 11:19 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
No, not bad at all. I'd be happy with that weight.
Old 05-20-2010, 01:39 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I'd be happy with that weight. I just weighed my 77 firebird with an aluminum headed BBC. It weighs 3640 with out me in it.
Old 05-20-2010, 07:33 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Originally Posted by 1BADRZ28
3455lbs with me in.
I am jealous of your hood.....
Old 05-20-2010, 08:03 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Im jealous of everything thats attached to it.
Old 05-20-2010, 10:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'd love to do a 4 corner scale some day. My car launches and drives straight and I have no idea how balanced the weights are. It's a gutted out race car and this year, I got the weight down to 3020 with me in it 20 more pounds to go and that's hard to find when I keep adding stuff.
Old 05-22-2010, 03:57 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
How much do you weigh?
Old 05-23-2010, 12:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Last time I weighed myself, I was around 170 pounds. I'm more concerned with race weight. Car, driver, fuel etc sitting on the starting line. That's how much weight the engine has to move down the track. The only time I want to only know just the car weight is when I want to know how much weight the car trailer is carrying.
Old 05-23-2010, 02:57 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I just wanted to know how much the vehicle weighed, because i am 295 Lbs, so it means allot for me to know where you are sitting with no operator inside.
Old 05-24-2010, 12:36 PM
anthony714's Avatar
alky i dont know where your located since im not good with longitude and latitud ebut if youre around chitown hit me up.i can do a 4 corner weigh
BrianChevy
Wheels and Tires
08-08-2019 02:16 PM
RedLeader289
05-28-2019 01:47 PM
ULTM8Z
DIY PROM
10-02-2015 01:25 PM
3.8TransAM
09-27-2015 08:37 PM
82xCAMAROxZ28
09-27-2015 12:31 AM
Quick Reply: Weight Loss Program
