Fuel filter before or after pump
Old 05-18-2010, 10:07 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
where should i mount the in line fuel filter i have. before the fuel pump inside the fender or somewhere between the fuel pump and carb? on my old carb the filter was actually in the carb.
Old 05-18-2010, 01:59 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The in-line filter should go between the pump and carb.
An '87 should have an in-tank pump. Is it operating? Has it been removed?
Old 05-18-2010, 03:16 PM
TNT_Z28's Avatar
Re: Fuel filter before or after pump
my car came with a pump on the side of the block. it was origanally an lg4.
would it really have 2 fuel pumps?
Old 05-18-2010, 11:05 PM
five7kid's Avatar
Engine: LS1/LQ4
Yes, the '87 LG4's did. An electric pump in the tank, and a mechanical pump on the engine. If the in-tank is not operating, the engine-mounted mechanical will not be able to keep up.
Old 05-19-2010, 09:32 AM
TNT_Z28's Avatar
thats f***ed up. now ive got a whole other headache to figure out
Old 05-19-2010, 09:51 AM
five7kid's Avatar
Engine: LS1/LQ4
Actually, it's a very good system. Pumps don't pull well, but they do push well. Having the pusher electric immersed in fuel in the tank prevents vapor lock and fuel starvation better than any other option.
Old 05-19-2010, 11:29 AM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Yup, he's right for the reasons he stated. I had one installed in my 84 under warrenty for that very reason. Vapor locking. You can check the intank elect pump by disconnecting the fuel line(remove gas cap) from the mech. pump inlet and put the fuel line into a container. Find the oil pressure switch (mine is located by the oil filter) turn on the key and jump the oil pressure switch.
Auggie
Old 05-20-2010, 12:14 PM
TNT_Z28's Avatar
what if its not working? would i be better off removing it and getting a high volume mechanical or fixing that one?
also would the intank pump have a relay? if so i think i removed it.
Old 05-20-2010, 02:02 PM
five7kid's Avatar
Engine: LS1/LQ4
The in-tank pump does have a relay. If it isn't there, I'd either put it back, or drop the tank and remove the in-tank pump. There is a sticky in the top section of this forum on how to convert to a manual pump type pick-up.
Personally, I'd want that in-tank pump working if I already had it. Even if I had to drop the tank to replace it.
Old 05-20-2010, 09:27 PM
TNT_Z28's Avatar
that makes sence.
before i removed the relay, i always heard a buzzing noise coming from what sounded like the rear axel area. it drained my battery whenever i left the battery plugged in, so for a while i unplugged my battery at night.
now that i know there is an in tank pump, im sure it was that. Would that mean that the pump was bad? should it be replaced?
i saved the relay. is there a way that i could wire that without connecting it to the computer?
Old 05-20-2010, 09:32 PM
shelad's Avatar
Car: 86 Camaro
Transmission: th350 w/2500 stall
Hey fifty7kid. I have a 86 Camaro. It started life with a 2.8. Not only is that long gone, so is the computer and wiring harness. I put a 350 in it with a th350. I'm running the mechanical fuel pump, but I see that you recommend using both. Is that a standard statement,or just for a particular application? My electric is still in there and relatively new. Is there a way of making it work with no computer, or anything? Also, my fuel pump losses pressure as its driven. Goes right to zero. When it cools, it starts at 61/2 - 71/2. I haven't bypassed the old stock filter yet. Any ideas? Thanks Larry
Old 05-21-2010, 11:32 AM
five7kid's Avatar
Engine: LS1/LQ4
You can rewire the in-tank to work.
Old 06-16-2010, 05:36 AM
RyanEricW's Avatar
Honestly, not sure about the filter being the issue. If filters can really be too small, or have a unwanted restriction it would boost pressure and lower your volume. Someone want to clarify about the filter?
What it sounds like though is a volume issue. Did you change all of the fuel lines when you swapped motors? The diameter of the fuel lines could be different (smaller) giving you a smaller volume, creating your issue.
Originally Posted by TNT_Z28
that makes sence.
Replace the relay and see if that works. IT is possible that the relay was stuck in the ON position.
If you don't know what a relay is, it is basically an electromagnetic switch. It allows you to control larger wire (big amperage)(fuel pump), with small wire (low amperage)(switch or small wires under dash). It is nice because it costs less, relatively less weight, and you have smaller wires under the dash = less potential hazard of a fire.
92camaroJoe
07-29-2023 07:57 PM
Infested
05-22-2018 11:56 PM
drewdock87
South Central
08-18-2015 09:02 PM
Winchester1094
08-18-2015 10:23 AM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: Fuel filter before or after pump
