door panel speakers?
Old 05-08-2010, 12:31 AM
jaymoung's Avatar
Car: 1984 Camaro z28
Engine: 350 small block
Transmission: 350 Turbo
hi im am doing some mods to my interior on my 84 z28 and i would like to install some more speakers and the door panels seem to be like the only place i can think to install more speakers and prolly the most popular other then the stock speaker locations only PROBLEM is i dont know how im am going to do this im sure its just a simple measure cut mount thing but i would like to get a how to kinda tutorial
please help me pictures would help out ALOTTTT
i236.photobucket.com/ albums/ff313/orinackra/4.jpg
SN i dont wanna fiberglass it
Old 05-08-2010, 01:22 AM
XxFormula87xX's Avatar
Car: 1987 Formula 350
Engine: 5.7 350 tpi
Axle/Gears: posi
Re: door panel speakers?
im pretty sure Q-logic makes custom kick panels the hold like 6.5 components. I plan to get a set myself.
http://www.hifisoundconnection.com/S...d/0/rid/123284
Old 05-08-2010, 01:23 AM
Stephen's Avatar
Car: 87 GTA
Problem with door mounted speakers, is they can't be very deep, because of the window. Set the speaker too deep & you won't be able to roll the window down.
The front kick panel is a popular location to put them.
Old 05-08-2010, 01:37 AM
jaymoung's Avatar
IVE SEEN THIS DONE AND ALOT OF OLD SKOOL CARS THEY ARE USUAL AT THE VERY BOTTOM OF THE PANEL
Old 05-08-2010, 01:54 AM
Engine: 5.7 350 tpi
Axle/Gears: posi
I think the problem is that the motor for the window is in that bottom corner, alot of people make custom door panels that come out more for the door speakers. I know on the new power doors im installing on my 74 K5 blazer the motor for the window is right in that front corner so now i need to move my 6.5s that I had in the old manual doors.
Old 05-08-2010, 02:00 AM
jaymoung's Avatar
YOU GOT ANY PICS?
Old 05-08-2010, 02:12 AM
Engine: 5.7 350 tpi
Axle/Gears: posi
no, i don't think its very hard to remove the door panel though. Ive noticed most people build basically a "spacer" so the speak doesn't sit so far in the door or at all, seeing this would lead me to believe that simply cutting a hole wont due the trick.
Old 05-08-2010, 02:58 AM
jaymoung's Avatar
kinda like this
Old 05-08-2010, 10:59 AM
Engine: 5.7 350 tpi
Axle/Gears: posi
yes. just like that.
Old 08-22-2010, 02:10 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Damn is it hard to do that?? Would you keep the stock speakers in the dash as extra speakers? That looks awesome!
Old 08-22-2010, 03:09 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the door panel's not very rigid, so you'll need to beef them up a bit if you dont want all your mids/bass to be absorbed due to vibration. best thing to do would be to make enclosures of sorts and bolt them to the door sheet metal. i did a 3-way setup (semi-successfully) in my last car with the tweeter and mid in the kicks and the midbass in the doors. If I do it again, I'd definitely just stick to a 2-way setup in the kicks. Best layout for distance and not a lot of work to get the setup to look well.
Hotrodboba400
12-10-2019 07:07 PM
RyanJB
05-07-2016 06:23 PM
tglennon11
09-23-2015 05:30 PM
NiG
09-07-2015 11:25 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: door panel speakers?
