Clstr Fuse?
Old 05-06-2010, 01:46 PM
Infested's Avatar
Clstr Fuse?
Hi, I searched around and couldn't really find the answer to my question, I have a '89 GTA and was wondering is the space for the CLSTR fuse supose to be void? I do not have the digital dash if that is what it was for, or am i just missing the fuse, because i have read elsewhere of other's peoples cars not having the fuse as well, and I personally don't notice anything functioning incorrectly besides possibly the steering wheel radio controls. Would love to find out more about it thanks..
Old 05-06-2010, 02:05 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Clstr Fuse?
Not uncommon to have one or two void fuse slots. Use a flashlight and check to see if there's a metal contact strip visible down deep inside of the slot. I have a couple of those void fuse slots, you might too.
Old 05-06-2010, 02:20 PM
Infested's Avatar
Re: Clstr Fuse?
Just checked and you're absolutely correct, there is no metal connecting strip in the fuse position. I am under the assumption that the fuse would have been for the digital dash option.
Old 04-18-2013, 11:26 PM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
Re: Clstr Fuse?
On my 88 Iroc the 5.7 TPI the CLSTR keeps melting. I have found that in my setup it powers the MAF burn-off Relay and my engine fans with ignition power.
I don't have digital cluster either. But I have the pin outs obviously.
In a book I have on an 88 f body repair manual it shows the CLSTR circuit working A/C Control Head, A/C Temperature Door Motor,Driver information Center (dic) display module. And then instrument panel for digital cluster.
In my Chilton, 88-89 shows the cluster slot as not filled.
3rd gen money
10-11-2019 09:57 PM
thunder57
11-07-2015 02:28 PM
AmorgetRS
09-28-2015 09:33 PM
lanceflame44
09-25-2015 12:28 PM
gta892000
09-16-2015 12:37 AM
Quick Reply: Clstr Fuse?
