tbi to carb conversion
Old 04-19-2010, 05:32 PM
Evilution's Avatar
Car: 1988 firebird formula
Engine: 305/ soon to be carbed
Transmission: 700r4 / soon to have stall
Axle/Gears: dunno but i have 4.10's on the way
hello all,
I'm Marty. I just bought a pretty clean 3rd gen 88 formula and definately want to go carb, im not into the whole trying to tune a tbi system. i know i need distributor, intake mani, carb, adj fpr w/ return line. what else might i need? basically what all do i need to convert to carb?
also i have no idea what distributor to run so can someone please shoot me some part numbers so i can look them up on summit. also i wasnt sure what dist gear i would need iron or steel as i have no idea if these are roller motors or not. once carbed and properly tuned for the cam will any of the shelf SBC cam work?
m
Old 04-19-2010, 06:17 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: tbi to carb conversion
https://www.thirdgen.org/forums/carb...bi-update.html
hopefully this will help you out.
Old 04-19-2010, 09:58 PM
Evilution's Avatar
Originally Posted by one92rs
it helped a lot. still curious are these roller motors or flat tappets? and will basic SBC cams work? what type of distributor gear do i need, or does it matter? thanks
Old 04-20-2010, 11:39 AM
Johnknight1981's Avatar
Car: 1989 Chevy Camaro Iroc-Z
Engine: L98 B2L 350 TPI
Transmission: 700R4 auto
Axle/Gears: 2.77
your motor is a hydro rollor cam if it is an 88 motor.
Old 04-20-2010, 11:42 AM
Evilution's Avatar
ok thank you do you have any idea what distributor i need for a carb swap? tried asking above and got no answer
Old 04-20-2010, 01:37 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The distributor need vacuum and mechanical advance. There are a lot of choices out there that meet that requirement.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
db057
04-28-2019 07:45 AM
383cam
09-09-2015 06:01 AM
willyjoejr
09-03-2015 09:26 AM
GeneralIesrussi
09-03-2015 03:23 AM
Quick Reply: tbi to carb conversion
