Rocker Arm questions.
Old 04-12-2010, 10:27 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Hi, i want to know if i can install a set of roller rockers on my stock 305 with l03 heads wich have the factory rockers wich arent rollers. Will 1.6 ratio not work, im kinda loss, dont know wich to buy and were, can any of u guys tell me if i can just install a set of roller rockers on my stock engine without having to modify anything else.
Old 04-14-2010, 04:02 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Rocker Arm questions.
Narrow body full roller rockers will fit with centerbolt valve covers, you may need to mesure if the pushroad lengt needs to be changed.
Old 04-14-2010, 05:30 PM
DSGx's Avatar
Engine: 305 TBI L03
Thxs, but will i need to modify anything to install 1.6 rockers ? Since they increase valve lift and stock swirl ports i have heard have small valve lift capacity.
Old 04-15-2010, 05:09 AM
thomas1976's Avatar
Car: 91 Trans am
The stock LO3 heads allow up to .470 in lift, safe. The LO3 cam with 1.6 rockers is in the .400 lift area.
I suggest you read the sticky treads, the search function is wery helpful too.
Old 04-15-2010, 09:09 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Where is the sticky pertaining to the 1.6 rollers...i can not find it...Thank you, Tom
Old 04-16-2010, 09:12 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
https://www.thirdgen.org/forums/tbi/...-synopsis.html
I posted cam specs with and without 1.6 rockers. I am personally running 1.6 Comp cam roller rockers on my car with no issues.
Old 04-17-2010, 01:38 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thanks....I seem to have pushrod clearance problems where the pushrods go thru the holes in the head...Is this common on these motors??? Looks like I may have to grind a little bit on each hole...Tom
Hotrodboba400
12-10-2019 07:07 PM
TX-SleeperC5
02-24-2016 01:34 PM
New2Chevy
09-28-2015 12:35 AM
ericjon262
09-11-2015 06:07 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Rocker Arm questions.
