LT1 T56 to an LS1?
LT1 T56 to an LS1?
Im not serious about it ,just making that 10 year plan for the car...
So I was wondering, how hard/expensive is it to attach an LT1 T56 to an LS1? I'd need an adapter plate I guess... or a new bellhousing... and I know the input shaft is a different length. But I just read something about the LQ4 having a different length crank and someone said to put an LT1 T56 on it, and that doesnt make sense to me because the bolt pattern is different... but I was thinking about putting an LQ4 crank in an LS1... although that might be a tad hard for a machine shop to balance. I would presume the counterweights would be too light for bigger LS1 pistons?
i'd just hate to buy a T56 twice. I rather like the one I have. But an LS1 is a ways off in the future for me anyways.
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
Re: LT1 T56 to an LS1?
This is what I did. I had a SBC stroker that I was going to stick an LT1 T56 behind. Long story short that motor is no more and decided to do the LSx swap. I found a guy on "tech" that had some parts trannys. I bought an ls1 input shaft and front cover from him to convert the LT1 T56 into a LS1 T56. All I had to do after that was locate the bellhousing. Shims were identical and everything. It bolted right up no issues whatsoever. There are plenty of posts out there with this info in them.
-Greg
-Greg
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The aluminum head, 24 tooth version LQ4's use the same crank as the LS1. Why would LS1 pistons be bigger than LQ4 pistons?
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
He's probably thinking of the old SBC guys that need a special flywheel to run a T56 on a 2 pc RMS crank
Engine: LS1/LQ4
Call me a wild and crazy out-of-touch visionary, but I would think you could have an LT1 flywheel neutrally balanced and use it on an early LQ4 with a LT1 T56.
-Greg
-Greg
What's so special about "early" LQ4's? Why are they different from later ones?
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
The LQ4 is a 6.0L
I do believe you will need the LS1 bellhousing, Im not sure on that though
Engine: LS1/LQ4
The first 2 years of LQ4's, the ones that came with cast iron heads, had a longer crank output flange than LS1's and the later LQ4's. That's what causes all the "issues" with using earlier transmissions with LS1's and the later LQ4's.
You can bolt an older bell housing to the LSx-family of engines. But, the engine doesn't have the 2nd bolt hole from the bottom on the right side, and has a bolt hole in the top center which the older bell housings did not. The overall shape and location of bolt holes remained the same.
I guess you were thinking LQ4 was a 5.3, so that explains your "larger piston" comment. LQ4 is a larger bore than LS1, but same stroke.
Can we just say that it would be simpler, and probably cheaper, to just get LS1 clutch and transmission parts than it would be to try to graft an LT1 T56 to an LSx engine?
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You will have to swap the input shaft, front cover, bellhousing, clutch assembly and throwout bearing/slave cylinder for it to work. The LT1 clutch is incompatible with the LS1 style flywheel which is totally different than the LT1 flywheel. A friend of mine who parts out 4th gens and knows them like the back of his hand was going to do this, and by the time he found the parts to do the swap, it was easier just to go ahead and put an LS based T56 in the car.
You could sell the LT1 style and purchase an LS pretty easy I would assume.
Your planning this for years in advance. Just save a few extra bones and get an LS1 T56... You can sell your current T56 and recoup some of the cost of the new one. If you arent doing this for a while, its safe to say T56s might even get cheaper by then. LS1/T56 combos most likely will...
Just isnt worth the hassle in my opinion. Why spend money to make the square peg fit in the round hole when you can just get a round peg?
J.
J.
