Differences between V6 cars and V8 cars?
Old 10-02-2000, 10:39 PM
Ih8myZ28's Avatar
Car: 1984 Camaro Z28 HO
Engine: L69
Hey all. I was just wondering what all the differences were between a V6 and V8 car?
I can get ahold of a V6 car real cheap, and would like to upgrade it to a V8 car but was wondering if it would be best to hold out for a V8 car.
I know the transmission is a weaker version, and the springs are softer. But what else is different about the V6 cars? Do they have a different rear-end in them as well? How about the brakes, are they smaller? Anything else you can tell me about the V6 cars that may cause a problem when updating it to a V8 car? Thanks!
Old 10-02-2000, 11:34 PM
82camaro's Avatar
Car: 82 camaro SC
Mine used to be a v6 car.
The springs are usually lighter.
The tranny won't bolt to a v8, so being weaker doesn't matter because you have to replace it.
The sway bars may be weaker and/or not have have a rear sway bar--mine didn't.
The rear-end is the same.
The brakes are the same(unless you compare it to a 1LE setup.
For me, buying a v6 car was great because it was cheap and I planned on replacing everything anyway.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
hectre13
Car Audio
26
03-03-2022 05:38 PM
InfernalVortex
04-20-2021 11:31 AM
Ed1LE
09-30-2018 09:14 AM
Zell1luk
09-29-2015 10:36 AM
tattmann
09-27-2015 05:20 PM
Quick Reply: Differences between V6 cars and V8 cars?
