700r4 Overdrive Problem
Old 03-21-2010, 11:28 AM
langss's Avatar
Car: Assorted
Engine: Various
Transmission: Manual and Automatic
The transmission will not stay in overdrive.It will go into overdrive if the car is going up a slight grade,but shifts back into third if on straight and level or slight downgrade.Anyone....Ideas....I have changed the fluid and filter twice.?????
Old 03-21-2010, 10:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 700r4 Overdrive Problem
Have you checked and adjusted the TV cable?
Old 03-21-2010, 11:09 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Your system runs on both the ECM and Vaccuum Pressure, if I'm not mistaken
It will kick out of over-drive and lock-up when the engine is under load
It will only stay in over-drive under easy-load situations, mostly, on flat stretches
Changing the fluids will not help
What year is your buggy?
Old 03-22-2010, 04:31 PM
langss's Avatar
Car: Assorted
Engine: Various
92 RS
Old 03-22-2010, 04:32 PM
langss's Avatar
Car: Assorted
Engine: Various
No I thought it might be something internal.
Prodigious
11-07-2020 09:23 AM
camaro11j
09-19-2018 08:49 AM
Prodigious
10-04-2015 11:20 PM
someone972
08-30-2015 12:52 AM
g.l.mos
08-22-2015 12:02 AM
Quick Reply: 700r4 Overdrive Problem
