clicking sound on new 350 irregular pattern
Old 02-28-2010, 09:56 PM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
swapped the 305 for a crate 355. I hear a clicking sound all the time when driving but its not clicking in a pattern, its random but frequent through all gears . When it clicks it feels like the car lunges a little like its getting more power and it revs a little higher, not enough to see it on the tach but you can hear it. It clicks once, sometimes twice sometimes 3 times every 4 or five seconds any ideas were to start?
Old 02-28-2010, 11:05 PM
matts86cam's Avatar
Engine: crate 355
Transmission: 700r
Re: clicking sound on new 350 irregular pattern
I am afraid I'll blow the engine up if I drive it and I need to get rolling down the highway again. I have searched TGO but I cant find anything similar to my problem. The exhaust manifold has a leak where it connects to the y-pipe and I plan on taking it to the shop but I need to figure out the pinging sound first.
Any suggestions on where to start?
Old 03-01-2010, 03:42 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Is it a click or a ping? In your first post you called it a click in your second you called it a ping? My first and probably best guess check over your plug wires. When they arc to say a exhaust manifold they happened to be a little to close to it will click and cause some driveability issues on the cylinder until the problem clears. This can be seen usually at night where any arcs will show up as flashes. Unless its directly shorted to something then there will be no flash so still check over your wires for cracks and melted spots. Exhaust leaks can cause clicks too but dont really cause drive ability issues. If its a ping its a totally different story.
Old 02-01-2011, 07:32 PM
matts86cam's Avatar
Engine: crate 355
Transmission: 700r
Thanks for the reply, it was a melted plug wire arcing.
Old 02-01-2011, 07:59 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Good to hear you found it, was gonna say exhaust leak
B_Dubya
08-26-2015 05:09 PM
Eric-86sc
08-24-2015 09:01 PM
crazynights
08-21-2015 06:53 AM
sreZ28
08-14-2015 07:48 PM
gta power
08-13-2015 06:15 AM
Quick Reply: clicking sound on new 350 irregular pattern
