Where do the O-ring Valve Stem Seals go?
Old 02-28-2010, 07:56 PM
RedRokkit's Avatar
Car: 1984 Trans Am, 1986 Fiero SE
Engine: 5.0 H.O., 2.8
Transmission: T5, M4 Muncie
Axle/Gears: 3.73 disc posi, CAVALIER AXLES!!
Do they sit in the groove on the valve under the keeper or do you push them all the way down to the guide.....I seached the net and theres too many conflicting "guides" TIA
Old 02-28-2010, 09:40 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Where do the O-ring Valve Stem Seals go?
The o-rings go in the upper "here" spot you labeled. They seal the retainer to keep a ton of oil from even getting to the umbrella seal.
Old 02-28-2010, 09:47 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
You position the o-ring on the valve stem under the keeper groove ON TOP of the spring retainer. This means you position the retainer, compress the spring, fit the o-ring and install the keepers.
Old 02-28-2010, 09:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
I find they go best in the trash.
Old 02-28-2010, 10:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Although they work, an umbrella seal on the intakes is far better.
As mentioned above, you compress the spring first then install the o-ring and keepers. If you try to install the o-ring before compressing the spring, the o-ring will get damaged or pop out of place.
Old 02-28-2010, 11:51 PM
RedRokkit's Avatar
I hear ya, the old ones had long since disintegrated....But they came with the gasket kit I bought, so I figure Id might as well install them.... Ill be getting new heads as soon as work picks up in the spring. Thanks for the help.
Bubbajones_ya
09-14-2015 08:38 PM
355tpipickup
09-13-2015 11:35 PM
bamaboy0323
09-12-2015 07:14 PM
BOOT77
09-05-2015 03:55 PM
tgp1990
09-04-2015 06:24 AM
Quick Reply: Where do the O-ring Valve Stem Seals go?
