Question about gauge senders and switches
Old 02-27-2010, 11:13 AM
DirtDawg57's Avatar
I got a new cluster with gauges to replace my idiot light cluster and I went to the auto store to get the sending units to replace the idiot light switches.
Well I got the oil pressure sender but when I asked them to look up the engine temp sender they could only get the switch to come up, so then the guy told me that they were the same thing and it doesn't matter. I didn't believe him so I went to another auto store and they gave me one but I'm still concerned that it might be the wrong one. Is there any way to tell by looking at it if its a gauge sender and not a idiot light switch? Or is there really no difference? Thanks!
Old 02-27-2010, 11:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Re: Question about gauge senders and switches
Measure the resistance. The switch is going to be either on or off, but the sender is going to have some value.
What's the part number for the sender you got?
Old 02-27-2010, 12:01 PM
DirtDawg57's Avatar
I forgot about looking up the part number, its a BWD part number WT3000Z. This is the description they are giving me on the sites that I found on search.
BWD Coolant Temperature Sensor
Temperature sensor design specifies tight tolerance thermistor response values to help assure accuracy of the temperature measurement and proper part operation.
Old 02-27-2010, 12:21 PM
Apeiron's Avatar
Engine: 383 Carb
Well the connector doesn't look right, if nothing else. A Standard Motor Products TS76 would work.
Old 03-01-2010, 10:16 AM
DirtDawg57's Avatar
Ok, maybe I'll try that. Thanks!
Ghettobird52
12-29-2023 08:23 AM
BRoss99
12-07-2020 06:50 PM
NBrehm
08-25-2015 11:49 PM
355sbcTPI
08-19-2015 04:38 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: Question about gauge senders and switches
