Camaro and T/A interchangeable parts?
Old 02-17-2010, 11:41 AM
sharkbite6000's Avatar
Does anybody know for sure what can be interchanged between the camaro and the T/A? I am looking at a 88 GTA that needs both front fenders replaced. I have found plenty of camaro parts through local listings. Can the camaro and GTA front fenders interchange? Also can the center consoles interchange. The camaro parts are all from a 88 Iroc Z28. Any help would be appreciated, I am eagerly looking forward to my first Trans Am.
Old 02-17-2010, 01:15 PM
AmorgetRS's Avatar
Re: Camaro and T/A interchangeable parts?
No, none of those parts interchange.
Old 02-17-2010, 01:20 PM
Ok thanks, I thought that was the case but I just wanted to ask somebody that knew more than me. Appreciate it.
Old 02-17-2010, 01:32 PM
AmorgetRS's Avatar
No problem. The fenders have the wrong curve to them and would sit way high in the nose area. The center consoles are nothing like as the Camaros center console are 1 piece while the Firebird have a seperate pod for the HVAC and radio.
Old 07-02-2014, 09:15 PM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Transmission: TH700-R4
Axle/Gears: 7.5" 3.23 Posi
I've scrapped my IMSA repliracer project Firebird but kept the fiberglass fenders for use on my 84 Camaro.
The rear fenders can be easily modified by cutting out triangular sections where the Camaro tail lights wrap around.
My question is how different are the Firebird and Camaro front fenders?
I'm pretty sure they're the same from the doors forward at least to the top of the wheel openings. Do the Firebird fenders slope down more steeply toward the nose after that? In a perfect world, my Firebird fenders will match up perfectly with the Camaro nose. Otherwise, I'll have to break out the fiberglass kit.
TIA for all inputs!
Old 07-02-2014, 09:50 PM
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Oh, well...
I dug out the fiberglass fender and answered my own question. Here's the pic:
Old 07-03-2014, 07:50 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
TIA for all inputs!
Kind of confused on your actual question, but you do realize that the rear does not have fenders?
Its a unibody, the rear is all one big piece. Modifying it is possible, but lots of work.
Old 07-03-2014, 06:50 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
The only interchangeable body parts are all the internal stuff (engine bay, cowl, floors,...), the roof, the doors and the deck lid and the glass of course.
The wheel arches are different, the quarter panels are different, the tail panel is different.
You can put an entire Camaro front end on a Firebird but it would look out of place with the different wheel arches.
So basically the only readily interchangeable body parts are the doors and the rear hatch.
Frozer!!!
01-19-2024 04:55 PM
IMissMy86TA
08-31-2015 08:40 PM
Akinnepa
Convertibles
08-26-2015 10:54 AM
Fronzizzle
08-09-2015 01:15 PM
1nastygta
08-08-2015 07:38 PM
Quick Reply: Camaro and T/A interchangeable parts?
