305 tpi considering supercharger or turbo kits?
Old 02-06-2010, 11:14 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
i have a 90 Camaro its TPI 305, im interested in maybe supercharging it or turbo. Are there any kits out there that are basically bolt on supercharger kits for my car, let me know thanks
Old 02-07-2010, 03:09 AM
AC
AC's Avatar
Car: Used to drive a camaro
Re: 305 tpi considering supercharger or turbo kits?
I've seen first hand what a Procharger D1SC kit can do for a 305 and it is a bolt on. That'd be my vote.
Old 02-07-2010, 11:45 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
how much money ya got to spend on it?
Old 02-18-2010, 07:12 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
I'm in on this one too. I'm going to be adding 113 Aluminum heads and a XR258 cam to my 305 next month, and somehow I just don't feel that it's going to be enough. I see a lot of options for TPI out there, how about a carb'd application in a 3rd gen? Anybody make a kit for that?
What kind of experience did you have with the D1SC kit?
Old 02-18-2010, 09:12 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
as far as my budget im not looking for a crazy power increase just a cheap little kit to wake up that 305 alittle
Old 02-20-2010, 07:41 PM
docpnutbutr's Avatar
Car: 87 Z-28, 89 GTA, 79 WS-6,
Engine: 87- 305 TPI, 335 stroker, 403 Olds.
Transmission: 700r4,700r4, and th400
Axle/Gears: mostly stock
I'm thinking of a similar set-up. My 305 is already stroked/punched out toa 335. I'd love a turbo but want to retain my TPI. A TPI just looks cool, like a metal octopus with its tentacles gripping the block. I already have the BBk twin 58 and matched runners, that addeda few extra ponies, but I'd love to add anothe 100 or so without the repeating expense of nitrous. Has anyone got a kit on the market that I might be able to adapt?
Old 02-21-2010, 10:21 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Hmmm... cheap and supercharging don't often go together very well. The cheapest way to up the output would be to put in a 5.7 haha
Old 02-24-2010, 09:46 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
yes good point, but im actually looking for a kit that is a direct application for these cars (mine has the alternator on the drivers side). Im not trying to break the speed of sound here just a low priced kit
Old 02-24-2010, 10:58 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Well like said above it's some money, no supercharger is going to be cheap cause low power don't really sell that much. I like superchargers over turbos, Superchargers just have a cleaner look to them.
Hawks has an 88-92 TPI Camaro/Firebird Procharger Kit that can be installed in about 10 hours with simple hand tools but the lowest power is still $4596.00. You could always build a cheap turbo or while I've never seen someone use it or build it, an Electric Super Chargers.
Old 02-24-2010, 11:23 AM
92droptopws6's Avatar
Car: 90 RS
Engine: 5.0 TBI
Transmission: Slushbox
Turbo FTW
Old 02-28-2010, 05:48 AM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
go turbo and get the car tuned
http://www.gmtuners.com/ --check this to get your car tuned these people know there stuff they did my V6 for twin turbo and ooo man even before i put it on just bigger injector was like wow. all custom work too and 1 year insurance too
Old 03-31-2010, 12:34 PM
detroit305's Avatar
I have a Paxton balldrive blower on my 86 305 tpi, it works pretty well, you might be able to find a kit on ebay etc as the kit is out of production. I wouldn't pay a lot for a used one unless I saw it run as abuse can kill the balldrive.
Old 04-16-2010, 11:16 PM
Bota 65's Avatar
Car: 1987 Formula
Transmission: 700 R4
Axle/Gears: 3.42 L/S
Where could i get one of these? at a reasonable price?
Old 04-17-2010, 11:21 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Simple man, what reasonable for one is not reasonable for another so here is the facts. The supercharger he is talking about is the big daddy of that Procharger kits and It will give you an 85%+ hp gain. that will run you from $4,936.20 to $5196.00. Now you could get a lower supercharger for $4,366.20 to $4596.00 and it will give you a 60% to 80% gain. I post above the link to this supercharger on hawks but you can get it at here but hawks make it a little easier cause they have the option to add the extra stuff that maybe needed to install it or upgrade it but as myself I like info and the above link has a much more in depth description to learn more about the supercharger and the company. Where you get it is up to you.
P.S. you can always go the cheap japan way
Electric Supercharger 5 PSI Vortex 15hp to 60hp - $200
Old 04-20-2010, 10:04 PM
Drac0nic's Avatar
Keeping the TPI or going carb is as simple as the plumbing. Regardless of what way you do it you need to accomodate the engine's fuel demands. Overall that is what matters. Look up the Hanger 18 mods and go get an Extreme Velocity bonnet or the Procharger bonnet and be happy. JMO on this turbo if you can fabricate and super if you can't. I've got 2 GN turbos waiting for my 305, a Megasquirt II and some 39lb/hr injectors.
Old 06-30-2013, 06:16 PM
kbish's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 V8
Transmission: Automatic
Has anybody done the cheap japan way that RS Reaper was talking about?
I have a 305 TBI, and I am interested in a little bit more horsepower. I dont know much about turbo/superchargers, but 5000 is way out of my price range. would an "electric supercharger" work on my car?
Old 07-01-2013, 12:17 AM
ZZ3Astro's Avatar
Car: 87 Iroc
We've seen electric supercharger posts and we've seen very old posts brought back to the top, but I think this is the first time both happened at the same time!
Old 07-01-2013, 12:34 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
The only thing that is good for is venting my bathroom after I take a dump...
Supercharging ain't cheap unless you can find a used kit. Another option would be to fab up your own turbo kit which I think would perform much better then a supercharger in the end for the 305.
Old 07-01-2013, 09:07 AM
toronto formula's Avatar
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
I just installed a used Paxton sn 2000. If you can find one you should be able to get one for less than 1200
Lots of used superchargers out there but the brackets are tough to find
Search craigslist
Wynjammer sells new sc kits for tbi
Old 07-01-2013, 09:27 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Lmao
Yep new kits arent cheap, i'd rather put 4-6 grand towards a new n/a or nitrous motor of bigger cubes and make more hp or similar hp as the blown 305
Used kits are likely better bet for cost.
If you can fab and weld, turbo setup is best bang for your buck
Old 04-03-2014, 04:43 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
A paxton ball drive unit would be your best bet. My friends 305 86 camaro went 13.2 @ 106 at NED with just 6 lbs and a small compucam small stall and gears stock intake and of course exhaust. Not bad and car was fun as hell to drive. You wont find any ati units cheap. Ball drive can be had for cheap.
Old 04-03-2014, 07:21 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
I pieced together my Procharger D1 kit for less than half the price.
Old 04-03-2014, 12:59 PM
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
The only thing that is good for is venting my bathroom after I take a dump....
Thats one hell of a dump. Does it suck the toilet paper off the spool?? lol
Old 04-03-2014, 04:34 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Its crazy how the prices have shot up. In 95-96 I bought one of the first P600b kits for the thirdgens. 3 core , polished pipes , polished compressor, billet impeller, extended warrenty, think I paid $2900 shipped to my door. Either a ball drive or a P1sc is plenty for what you want, if you can find a vortec too as well. Dont mind the no intercooler thing at 6-8lbs which is totally safe on the street, add a 50/50 meth kit to it you would make an extra 100hp easy. Be streetable and reliable. I went 12.60 back in 96 on 9lbs bone stock motor at 111mph on an ATI kit. Ball drives are dirt cheap and bet you could find a kit around $1000. Vortecs maybe $1500. More than youll ever need. Easy 450+to the tire with meth on 6-8lbs. Big swap meet this weekend in CT. Might want to check it out. Take care.
Terrell351
06-13-2021 01:13 PM
gta90
09-15-2015 04:00 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: 305 tpi considering supercharger or turbo kits?
