2ND Gen Rear-End
Old 02-04-2010, 07:29 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
2ND Gen Rear-End
Found this posting on craigslist, and think I know the answer but Figured I'd ask.
8.5 COMPLETE REAR DIFFERENTIAL OUT OF MY 77 CAMARO, NEW 373 GEARS, NEW POSI UNIT, MOSER ALUMINUM REAR GIRDLE. NEW PARKING BRAKE CABLES, WHEEL CYLINDERS, BRAKE SHOES AND BRAKE DRUMS.
How much fabrication would it take to fit a 10 bolt 8.5 rear out of a 77 Camaro into a thirdgen?
I know It's not a direct bolt-in like a 4th gen rear, but are we talking minor modification or major engineering?
Old 02-04-2010, 07:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 2ND Gen Rear-End
Major engineering. Swapping over the spring, shock, LCA and panhard mounts over is easy. Trying to fabricate some way to attach the torque arm is difficult. By the time you're done, it can be a lot easier and cheaper to just buy an aftermarket direct bolt in diff.
Old 02-04-2010, 08:11 PM
92droptopws6's Avatar
Car: 90 RS
Engine: 5.0 TBI
Transmission: Slushbox
This swap is a bit more involved however can be done if you can or know someone that can weld...
You can used vitually ANY rear end,12-bolt,9",8.8,8.5 etc....
I am using an 8.8 rear on my car(not installed yet) most 8.8s from explorers come with lockers 31-spline axles and either 3.55,3.73 or 4.10s.generally no more than 250.00 from salvage yard!You can always redrill axles and rotors to retain GM bolt pattern on the Ford...my total is 850.00 for mine
You can purchase these parts
http://www.g-forcesuspension.com/pag...og/i.php/81/55
or make your own at a much lower cost....next lik has pix to get an idea of what i am getting at... http://www.ls1tech.com/forums/gears-...8-8-build.html
my86bird
10-23-2015 12:20 PM
NiG
10-11-2015 08:42 PM
New2Chevy
09-28-2015 12:35 AM
Hotrodboba400
09-02-2015 07:28 PM
tricky1
08-23-2015 01:17 PM
Quick Reply: 2ND Gen Rear-End
