151 iron duke to GM 350 crate engine, need advise!!!
Old 01-25-2010, 07:06 PM
pontatack301's Avatar
i have a 82 firebird with a 151 ci four cylinder, 4 speed maual. i want to put a 350 crate engine in. but im stumped on one topic!!! i do not have a hydrolic clutch if your familiar. my number one question is the pivoting arm for the clutch that is mounted from the left frame rail to the side of the engine block! where would i bolt that on the v8? also do i go and just purchase v8 motor mounts? i have a saginaw 4 speed. Do i need a different bell housing? im after 250 horse power i was told the current trans will handle the power? do i need a different engine harness? if anyone has a moment to reply i would apreciate it so much!!
Old 01-25-2010, 09:19 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: 151 iron duke to GM 350 crate engine, need advise!!!
bump for a good question. I'm not 100% sure but I think you might just need to get all V8 hardware...
Old 02-03-2010, 05:19 PM
KennyC's Avatar
Car: 1985 Firebird SE
Transmission: 700-4r
Axle/Gears: 9 Bolt
Here's what I can tell you out of my general car knowledge.
#1 - your transmission will NOT work, but, it has nothing to do with the horsepower level. The iron duke 151 shared the same "60 degree v6" bellhousing pattern of the 2.8 v6 engine... this is different than the standard SBC pattern. By the time you bought atapter setups,l you'd be ahead to get a stronger transmission to start with.
#2 - your iron duke engine was fuel injected. You need to decide whether you are going to run a fuel injection set up of some sort (TBI, TPI?) or a carb, and if a carb, are you going mechanical or electronic controlled. No, the plugs on your TBI harness are NOT the same as what would be needed to plug into the v8 TBI. Regardless you are looking at a different engine wire harness, because the plugs and lengths need to run to different places, the engines are different sizes, etc.
#3 - I have a little info on the motor mounts, a starting place to research a bit: I've heard the 151 had its motor mounts in the same place as a 301 would (that it was designed as one cylinder bank of a 301 similar to how a chevy 4.3 is 3/4 of the length of a sbc) In theory, you SHOULD be able to drop any pontiac v8 whether it is 301/350/400/455 into the same mounts and just put a new tranny/harness in around it. What I do *not* know, and I *assume* to be different, is that the sbc and pontiac v8 use different mounting holes on the crossmember for the engine pads. if you had your engine out, and a junk sbc block for mockup lying around, you could measure and see if they are the same.
Something you didnt mention, but I assume you know, is you likely need to upgrade your fuelpump in the tank as well, BUT eliminating the computer should mean going to a mechanical pump and changing that sending unit on the tank from a electric pump to a mechanical (if the computer is eliminated, nothing there to tell the pump to turn on).
I've got a 85 bird here I'd been trying to sell for a while and pick up a duke car thats nearby, but, no takers in this economy so I've researched the reverse of what you are and am looking at ripping out my sbc and converting to the 151
theshackle
09-17-2020 08:26 AM
theshackle
03-05-2017 06:37 PM
masonta
08-31-2015 10:14 PM
InfinityShade
08-22-2015 08:00 PM
ezobens
DIY PROM
08-19-2015 10:29 PM
Quick Reply: 151 iron duke to GM 350 crate engine, need advise!!!
