700r4 to mph to rpm calculator
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
I'm trying to find a good calculator to figure out what rpm my engine would be turning at at which speeds when I swap out the rear end. There are a lot of T5 one's, but I can't find a 700r4 one. I need to know what first and second gear shifts at under WOT and what rpm my engine will turn at 60 or 70 with 3.42's and 3.73's. Thanks!
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: 700r4 to mph to rpm calculator
I have all these calculations on a spreadsheet for comparing these gears....I'll post them tonight when I get home for you....I did speed, cruising, rpm drop when shifting, etc. etc.
You'll like it, be on here about 5 hours from now.
Car: 83 Camaro
Engine: 383 CI
Gear Rear end Speed
ratio ratio Gearing per 1000 rpm
3.06 3.42 10.47 7.28 mph
1.62 3.42 5.54 13.76
1.00 3.42 3.42 22.30
0.70 3.42 2.39 31.85
For the 3.73 gear
Gear Rear end Speed
ratio ratio Gearing per 1000 RPM
3.06 3.73 11.41 6.67 mph
1.62 3.73 6.04 12.61
1.00 3.73 3.73 20.42
0.70 3.73 2.61 29.18
If you want to shift from 1st to 2nd at 5,500 RPM with a 3.42 rear, you will shift at around 40 mph.
I hope this is what you want.
Engine: M54 DOHC I6
Axle/Gears: Stock
For the 3.42 gear
Gear Rear end Speed
For the 3.73 gear
Gear Rear end Speed
Gear Rear end Speed
For the 3.73 gear
Gear Rear end Speed
Engine: M54 DOHC I6
Axle/Gears: Stock
Thank you so much, please do! Thanks, you're a life saver haha.
TheTraut88
09-07-2015 05:22 PM
