Super small little bumps in new paint job
Old 01-20-2010, 10:11 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Earlier I posted about a 2 month old paint job bubbling. Well, that bubble got to a certain size and stopped growing so I figured it was small potatoes to get it fixed. Now I'm starting to notice a bunch of super small little bubbles all around the car. I'm not even sure if they are bubbles. They are like little specs mostly on the hood and rear quarter. What is this a sign of?
Old 01-22-2010, 01:04 PM
87_Injected's Avatar
Car: 2011 2LT RS
Re: Super small little bumps in new paint job
It means they didn't prep the car right and there was a chemical reaction causing it to bubble. I had that happen on two of my cars in the past. Do you have a warranty on the paint job? If so .. tell em to do it again and do it right!
Old 01-22-2010, 06:20 PM
UDAMON's Avatar
Car: Mazda Protege5
those little specs may be solvent popping. its when the coats are applied too heavy and/or not enough flash time between coats. when you put on a coat and the previous one is still "breathing" the solvents dont escape completely resulting in these tiny bubbles trapped in the next coat. only fix is to recoat.
Old 01-22-2010, 11:58 PM
aarivers's Avatar
Car: 1991 Chevrolet Camaro RS
Transmission: T-5 Manual
Axle/Gears: 3.42 4th Gen
Man that really sucks, sounds like fisheye's caused my silicon getting into the paint, usually happens due to poor prep work, mostly around areas where Armor All or some other silica based shine spray would have been applied, like the fender areas, rubber seals.
Only way to repair is to sand down and repaint, color and clear.
Old 01-23-2010, 08:22 AM
miner's Avatar
Car: 88 Iroc-Z
Transmission: T-56 Manual
Axle/Gears: 3.23 10 bolt
I have the same problem. Macco repained it once, looked at again and it happened again. They ended up deciding to give me my money back.
Old 01-23-2010, 04:16 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Maaco does crappy work anyway.
Old 01-24-2010, 03:57 PM
1bad71's Avatar
Car: 91 camaro z28
Transmission: turbo 400
Axle/Gears: 9/bolt
x2. had the same problem, with the paint i put down in my engine compartment.
it turned out the spec sheet i got was wrong for the paint i was using, and it caused it to solvent pop. looked like i had threw sand on it before it dried!
i wet sanded the whole thing with 400 and then re-wiped it down with wax/grease remover, then i reshot it with two good coats. came out a 100% better.
dustint209
09-09-2015 08:09 AM
neekolzun
08-24-2015 04:59 PM
kah992
08-19-2015 02:55 PM
kyle5647
08-07-2015 03:08 PM
Quick Reply: Super small little bumps in new paint job
