Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How much hp to run 11 sec et
Old 01-08-2010, 09:46 PM
gtanut's Avatar
wondering how much power it takes to put a 3500lb 3rd gen into 11s with out the bottle iam building a new motor and it is the last one for a while i have changed motors and trannys way to many times in the last 3 years thanks alot
Old 01-08-2010, 10:10 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: How much hp to run 11 sec et
400 FWHP should get you there. I doubled checked on the HP calcualtor and it agrees.
Old 01-08-2010, 10:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
depends on alot of things like suspension/gearing/tranny etc.
Just to break 11.99 with a great chassis setup and perfect gearing, I think you could do it with 400-420 crank hp.
Not so great chassis setup so abit softer launch, and you will need to make up for it with hp, 450 or so.
I ran 11.4's with decent launch and 400 hp at the tires. 350-360 should do it in a 3500 lb car with decent launch. 370's would be better
Old 01-08-2010, 10:24 PM
gtanut's Avatar
the motor i doing now should dyno at about 540 hp and 550 tq i hope it does the trick because i am not changing motors again if i dont have to oh yea then i am going to throw 150 worth of nitrous at it
Old 01-08-2010, 10:51 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
You can get 10s with 500 HP with the right setup, do 540 and 550 TQ makes it easier.
Old 01-08-2010, 11:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's cheaper to go faster by reducing weight before adding HP. There does come a time when it becomes cheaper to make HP than reduce weight but you're a long way off from that.
As mentioned above, you need to make at least 400 HP to break into the 11's. Below 11.50 and you'll be adding more weight back into the car because at that point, you'll need at least a 6 point roll bar.
500 HP might not get you into the 12's if you can't get the power to the ground. A good chassis setup and sticky tires are required for fast times or you'll just spin off the line and lose it all.
Old 01-09-2010, 08:35 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Check my signature.
Post your motor specs and car combo. I'd like to know what you are building that makes that kind of TQ.
rolljitsu (06-14-2021)
Old 01-09-2010, 09:45 PM
gtanut's Avatar
itis a 468 10.25 comp procomp320cc heads cam is 244 at .50 with about .580 lift and a single plane intake i am stumped on what carb to run holley said to run 950 hp but i think that is way to big car is a 1987 gta guy building motor said power figures should be right around there thanks for all the input guys
Old 01-09-2010, 10:11 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
I was guessing BBC. Thats a car I would like to build myself...468/GTA
Good luck. It should go Elevens no problem.
Old 01-09-2010, 10:13 PM
gtanut's Avatar
hey thanks alot
Old 01-16-2010, 04:40 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
950HP is equivalent to a Demon 825. It is just a 750 with an 850 baseplate. 1000hp is Waaaayyyy more carb than a 950HP.... 950hp is just a name...
with that said buy a Demon 825 or the 950HP...your choice
Old 01-16-2010, 11:03 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Axle/Gears: Ford 9" with 3.89
My car with n/a 377rwhp and a estimated 485flyhp ran a 12.09.
On a slightly better air day I would have been in the high 11's.
Combo in the sig.
With your combo if you dont run 11's, something is terribly wrong.
Old 04-10-2010, 08:53 PM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
I ran a best 11.98 @ 111mph first time out. I have an 87 with 396/TH400 and a bone stock 7.5 rear with 4.10 gears (I don't anticipate this lasting very long) and 9x30 inch ET drag slicks. Subframe connectors and tubular lower control arms round out the suspension. I've since tweaked the ignition and added a 2-step. Alky is absolutely right about the weight. I have removed everything not necessary for this thing to drive. I'm pretty sure I'm still above 3100 lbs. I've already ordered an 8 point from S&W. Before I go back I'm gonna get the roll bar installed. I just have a feeling....
Old 04-14-2010, 06:26 PM
1hotroc's Avatar
Car: 87 iroc
Engine: 5.7 ZZ4, AFR, Stealth Ram, Comp cam
Transmission: 1993 T56 viper internals w Spec3+
Axle/Gears: moser 9" truetrac 3:89
Ive got a 87 iroc 350 t-top car all the mods stealth ram etc.. running a t56 with a borg warner 3:45 gear. It made 383hp 383 torque on a dynojet. I really want to get in the high 11's with a manual trans. Is this going to be possible with this combination? Also how do you launch a stick car at the track? I used to have a 700r4 with a 3500 stall. There's t56 cars going 10's and 11's am I right?
Old 04-15-2010, 06:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Theres T56 cars in the high 7's but stupid power is needed
87 TA used a T56 for a few years after his auto trans. Never did match his best n/a time with the stick as it couldnt quite launch as hard but I believe his clutch was going out when he started to figure out how to launch it.
YOu really want to give it some rpm and kinda quick slip the clutch out. If it bogs then either slip the clutch abit more or raise rpm to launch. YOu need to practice to get the hang of what your car wants.
Old 04-17-2010, 10:31 PM
Stevo's Avatar
Car: Pair of 92 Z28s
What T56 car is in the 7s?
I know of a supra with a 6 speed...is that classified as a "T56"?
Old 04-26-2010, 02:00 AM
Night rider327's Avatar
Car: 1988 Camaro
505 HP at crank in mine went 11.40's @ 118, with 60' times in the 1.60's
3223 lbs race weight on car, plus me at 275 lbs, so 3,498 lbs
3.42 rear gear, 275/60-15 nitto drag radails, 2800 stall converter, th-400 trans, spohn adj panhard, lca, lca brackets, sfc, jefster adj. tq arm, KYB AGX adj. rear shocks, drag bags, s&w 10 point roll cage,
Old 04-26-2010, 08:04 PM
1hotroc's Avatar
Car: 87 iroc
Very impressive. Do the airbags go in the place of the coil spring? I cant get my car to plant and hook! I plan to do some 5k clutch drops at the track.
Old 04-26-2010, 08:14 PM
1hotroc's Avatar
Car: 87 iroc
Is there any 11 sec t56 third gens out there? I would like to hear from you, Let me know your combinations and tricks to see some high 11's! Thanks!
Old 04-27-2010, 01:06 AM
Car: 1988 Camaro
Thanks. No the air bags don't replace the springs, they go inside the coil springs so you can adjust the "spring rate" and the level of the car. Really helps to level car and put more even weight on both tires
Heres a couple of pics
http://rides.webshots.com/photo/2325...41290424rcldAA
http://rides.webshots.com/photo/2885...41290424CJIIHv
http://rides.webshots.com/photo/2913...41290424xxJnac
Get a buddy and a tape measure or yard stick out. Bring up the RPM with clutch out and foot on the brake. Let your buddy measure the height from ground to pass side of rear bumper, then move over and measure the driver's side.
One side will lift higher than the other. Thats un even load on tires. By changing the air pressure in the bags you can get the car level ubder power.
I can't remember the #'s off the top of my head but just adding the air bags and getting the pressure adjusted right knocked around .05 seconds off my 60' time
Old 04-27-2010, 01:16 AM
Car: 1988 Camaro
Thanks.
The bags dont replace the springs, you just put them inside the springs. They help to even out the load on each tire with car under power.
Heres some pics of mine
After installing mine and getting the air pressure adjusted right on them for my combo, by 60' times dropped by .05 second.
Old 05-22-2010, 09:10 AM
1hotroc's Avatar
Car: 87 iroc
I dont mean to beat a dead horse, but what gears should I use to try to get into the high 11's? Im pretty sure the 3:50 set in my ford 9" wont do it. So I was thinking three choices the 3:73's, 3:89 or 4:10's. I have the early t56 with the 2:97 first gear ,also my car is 3500lbs made 383 wheel hp and 383tq. Help me out! I cant decide what gear? Oh by the way Im running a 26" tall tire out back. I really hope someone out there can give me some good advice. Thanks...
Old 05-23-2010, 10:38 PM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
http://www.5speedtransmissions.com/gear_calculator.html This is a link to a gear calculator and you can choose aftermarket T56 which I believe has your gear set out of that list. I would need to know your max RPM for the motor to tell you for sure what gear would work best. Assuming you shift at 6500 a 4.10 gear would be ok because you would shift out of 4th at 123 which is a low 11 almost 10 second pass but if you shift out of gear at 6000 you would shift out of 4th at 113 and might not be so good depending your time you run. I am basing this all on not shifting past 4th gear in the quarter because that wouldnt be optimal seeing it has the whole double overdrive aspect to it. So either let us know your redline or mess aroudn with that calculator and you will be fine. Good luck.
Old 05-24-2010, 11:45 AM
1hotroc's Avatar
Car: 87 iroc
Thanks. My car makes peak hp at 5800 rpm, so I need to be around that rpm in 4th gear going thru the traps. I cant figure out that calculator? I dont want to overgear it ya know what I mean?
Old 05-24-2010, 06:14 PM
gtpro700's Avatar
Alright so if it makes peak at 5800 and you shift every gear at that RPM you will hit 115 MPH through the traps in fourth gear with a 3.89 rear gear. Im guessing it will be safe to say that you can spin your motor to 6000 still and that will have you trapping 119 in 4th also. 115 MPH roughly works out to a 11.8ish and 119 MPH is definitly a lower 11 second pass. I think the 4.10s might be too much if you dont shift higher then 6000. If you can spin the motor to 6500 or even 6200ish you might be able to get away with the 4.10s. Just gotta know where you will shift your gears at and you can make a final decision.
Old 05-24-2010, 07:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
With a T56 and a good grippy clutch, you may need a good rear gear to make sure it doesnt bog out the hole. 4.10's is probably what I'd use with peak hp at 5800, depending on how well it holds after that. Shift by 6200 in first/second, 6000 or so in third. try that. 383whp should trap 115-117 which is in the 6100 rpm range thru the traps. If that is abit too much, step down 3.89/3.90 or w/e is available in a 9".
If you are ever going to spray that car, go much lower on the gear. 3.73 or less for sure.
Old 05-24-2010, 09:45 PM
1hotroc's Avatar
Car: 87 iroc
Thanks for for the input. I also wanted to mention that the t56 that I have is an early version with a 2:97 first gear so Im thinking with a 4:10 gear that might be too much ya know an unusable first gear? (kind of like a dump truck taking off). So if I could get my car in the 11's with a 3:89 gear I would be very happy because it would also be easier on the highway for long trips. Thanks for all the advice.
Old 05-29-2010, 05:15 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I'm also hoping my combo will put me in the 11's as well. Engine made 467 HP and 517 TQ at the crank. Car weight is 3252+200lb driver..mods in sig..you guys think I'll get into the 11's?
Old 09-22-2010, 06:43 PM
1hotroc's Avatar
Car: 87 iroc
Im so pissed! The best I could do was a 12.75 at 111.76. Horrible 60 ft. 1.961! I was going to make another run but I snapped my aluminum 4th gen drive shaft in half! I really dropped the tire psi and heated the tires up along with a 4000rpm clutch dump. I did see cars mph at 112 and they were doing high 11's, What can I expect with like a 1.6-1.7 60 ft? What gets me, my car had less hp with an auto w3500 stall and I was doing 12.53 at 108mph! with stock 3.27 9 bolt, now I have a currie 9" with a 3.89. Is it time to but back the 700r4 or are stick cars just slower!
Old 09-22-2010, 07:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
wow surprised at the low mph for the hp you have to the ground.. 383whp should easily go 115mph and mid high 11's
Old 09-22-2010, 07:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Factory aluminum driveshafts are not very strong especially for drag racing.
With a bad 60' time, you either have tires that won't hook up or suspension that isn't letting the tires hook up. You want to launch where the engine makes the most torque. 4000 is probably too high.
Old 09-22-2010, 07:57 PM
On Probation
89fbirdformula's Avatar
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
demon carbs are JUNK.
prosystems carb FTW.
Old 09-22-2010, 08:13 PM
1hotroc's Avatar
Car: 87 iroc
really? 115mph? Even with 3:89 gears. On my last run that I could'nt make I tweaked the timing up to 35 degrees hoping to get a better mph. I also wasnt going to get off the gas at all between shifts. Theres no telling what would have happened because its all speculation but it looks like I may need to change the cam in my motor to get this thing in the 11's. the 224/230 isnt cutting it. Can you reccomend a nice cam for me? 350zz4 with afr187's stealth ram 30lbsvo 1 3/4 sLp's. Need some good advice or Im going back to an automatic.
Old 09-22-2010, 10:25 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
sounds like you need the driver mod first
Old 09-23-2010, 06:47 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I have a 236/242@.050 (109LSA) cam in my stock L98. AFR190 heads, 3600 Stall, 4.10 gears, single 3" exhaust. Witht he old miniram setup, it went 11.60 at 117 at sea level. Switched to an Air Gap with a Mighty Demon 750 and went 11.89 at 114 in a 3000' DA (1.61 60'). The car is much faster now with the Demon carb...lots more torque. I never dyno'd mine, but I would guess the motor is making 465-475HP...probably 390ish to the ground. Car probably weighs around 3500lbs with me in it (only thing removed is the passenger seat...for tool room).
Your setup sounds similar, so I think an 11.90 for you isn't out of reach. Will be real tough with a stick shift though. You need to practice, practice, practice...
Old 09-23-2010, 07:03 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Work on the driving and tuning first. It may have an 11 in that car you just need to drop 60 foot a few tenths. stick cars need to rev up high at the line and quick slip the clutch to get the best launch. Try different things and see what it does
Old 09-23-2010, 08:32 PM
1hotroc's Avatar
Car: 87 iroc
Thanks guys for the words of encouragement. Im going to make a few changes and head back to the track to see if I can save face (lol). One more stupid question. Do you think that mobil 1 15w50 is too thick of an oil to be running in a zz4? I normally run 5w40 mobil 1 but Im also wondering if this thicker oil is robbing some valuable horsepower.
Old 09-23-2010, 08:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah thats pretty thick. I'd go abit thinner if you can. I've always run 10w30 in my motors. Thinner should free up a little bit of power but its nothing noticeable.
Old 09-23-2010, 08:48 PM
mw66nova's Avatar
Engine: 7.0L
what are the bearing tolerances set up as?
Old 09-23-2010, 09:13 PM
1hotroc's Avatar
Car: 87 iroc
Dont know about the bearing tolerances but its a stock zz4 shortblock thats never been apart. Im going with the thinner oil, thanks, Im also going to change the thermostat back to a 180 from the 195 thats in there now. I need to squeeze as much hp as I can.
Fast355
12-02-2016 06:33 PM
perZ
08-21-2015 05:51 PM
Winchester1094
08-18-2015 10:23 AM
eightsixseven
08-14-2015 03:09 PM
Armored91Camaro
DIY PROM
08-12-2015 09:41 AM
Quick Reply: How much hp to run 11 sec et
