305 to 350tpi swap
Old 01-06-2010, 06:44 PM
88 iroc josh's Avatar
305 to 350tpi swap
i have an 88 camaro 5.0tpi 5-speed, and i want to drop a 350tpi into the car. what would i need to do will the tranny just bolt up to it?
Old 01-06-2010, 08:08 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 305 to 350tpi swap
Yes your tranny will bolt up to it you will need a new tune though for your engine
Old 01-07-2010, 04:43 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Different knock sensor.
ECM for correct year/size. boneyard specials are cheaper than your average OTC tune.
The easiest would be to grab a 350 from the same year as your 305 this way you don't have to worry about different harnesses. i.e. SD - MAF
Or just build a 350 short block and transfer your entire intake over.
Old 01-07-2010, 05:25 AM
thanks. I didnt know that i would have changed the prom and knock sensor . my car is an 88 and the 350tpi is an 88 tpi from a transam!! perfect. so i need to change nothing besides the motor
Old 01-08-2010, 05:21 AM
i have an 88 and the engine is from an 88 that im going to swap.
will i have to still change the knock sensor if so how much are they and where is it located on the motor
Old 01-08-2010, 11:18 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
and the ECM chip and all the 350 sensors, but if all the sensors are still on the 350 then its plug and play if you already have the chip for it
Old 01-08-2010, 10:34 PM
T-rock's Avatar
Car: 1987 camaro iroc
Transmission: 5 speed borg warner
Axle/Gears: 3.45
305 TPI to 350 TPI Conversion
If you are looking to convert your car from a 305 TPI to a 350 TPI setup, then you should find the information below rather useful. These are all the needed changes to do the conversion.
First of all, the TPI intakes (manifold, plenum, fuel rails, throttle body, runners) were exactly the same between 305 and 350 engines of the same year. There were no differences in these parts whatsoever between one engine size and the other during any year (there were however differences between the intake manifold and fuel rails between the Camaros and Corvettes). For example, a 1987 intake was the same for both a 305 and 350. Please note that this does not mean all intakes are the same throughout the years, there are differences between a 1987 intake and a 1992 intake for example.
All your belt driven accessories, brackets, exhaust, etc... will transer over from the 305 to the 350 without any problems. Once you install the TPI intake on the larger engine, you will need to note the following items that need to be changed. These are the only things you will need to change or worry about to properly convert to a 350:
Injectors
The size of the injectors was a very important difference between 305 and 350 applications. ALL 305 TPI engines came from the factory with 19 lb injectors. ALL 350 TPI engines came from the factory with 22 lb injectors. The Corvettes did not have injectors any larger than the Camaro, as I have people often asking. If you want to use 19 lb injectors on a 350, or 22 lb injectors on a 305, you can, but you MUST have the injector size in the PROM changed. Otherwise, you will run into fueling problems.
Knock Sensor
The knock sensor physically looks the same between the 305 and 350 version, but they do are not the same. This is very important, and should not be overlooked. The knock sensor is responsible for detecting detonation. Detonation produces a specific frequency that travels through the engine block. This frequency is different depending on engine size. In addition, it is important to note that the 350 knock sensors were different between the 85-89 TPI setups and the 90-92 TPI setups. You must use the correct one for your application. The 305 knock sensors were also different between 85-89 and 90-92.
ESC Module
The 85-89 TPI setups used an external ESC module which was mounted by the firewall. This module was different between 305 and 350 engines. Changing this is as simple as disconnecting the 305 module, and plugging in a 350 module. The 90-92 TPI setups did not have an external ESC module. Instead, the ESC circuitry is contained inside the PROM. For this and several other reasons, it is important that you use the correct prom for the engine size you are using.
ECM
Although there were several different ECMs used depending on what year TPI setup you have, the same ECM was used for 305 and 350 engines for a given year. The difference between the engines was the prom. In other words, the 86-89 350 TPI engines used the 1227165 ECM, and so did the 86-89 305 TPI engines. The 90-92 350 TPI F-Body engines (Camaro and Firebird) used the 1227730 ECM, and so did the 90-92 305 TPI engines. The 1985 305 TPI engines used 1226870 ECM, which is the same as the 1985 350 TPI ECM (350 was only available on the Corvette in 1985).
The Corvette used the 1227727 ECM on the 90-91 350 TPI engines. Although the Corvette was never available with a 305, the 1227727 ECM can be used on a 305 if desired.
PROM
This is probably the most important change that needs to be made. Regardless of what ECM you are using, the 305 prom is setup very differently from a 350 prom. Which prom you need will depend on what ECM you use, transmission type, engine size, and a few other details. Contact us if you need help finding the correct PROM for your application.
If you have a 90-92 ECM, and you are having your PROM reprogrammed, you must start with a PROM that was originally for a 350. The 90-92 PROMs have the ESC circuitry onboard, and that cannot be changed.
The 85-89 PROMs can be changed from one engine size to another without worrying about ESC within the PROM, since the module is external on those years.
Old 05-17-2010, 05:11 AM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
So what happens if I dont have an ESC off my 86 TPI setup??
Old 07-04-2012, 10:06 PM
Guest
Guest
Posts: n/a
hey where can I find a chip for my 1991 firebird 5.7 swap tpi? Please help
Old 07-05-2012, 08:17 AM
Car: 91 Trans Am
Engine: 355 TPI
Good luck finding that. hawksthirdgenparts.com might have them. Keep in mind they will cost a little more than earlier chips. why you may ask? well because the electronic spark control in part of the MEMCAL (aka chip)
Old 07-06-2012, 12:35 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
And the fact that the AUJP prom only came in 2 years... Honestly for the price you would pay for a aujp prom you might as well go with the p4 ebl flash or save $ and burn a custom prom that shadows the aujp and use a 90-92 305 tpi for your limp mode backup
xkingcodex
02-12-2020 07:43 PM
Orr89RocZ
04-25-2016 08:28 AM
theurge
08-21-2015 12:46 PM
1989formula5.7l
08-15-2015 11:35 AM
st.evel07
08-13-2015 06:15 PM
Quick Reply: 305 to 350tpi swap
