Convertible Top Glue?
Old 01-06-2010, 12:40 AM
sprslo92's Avatar
Car: 92 z-28 vert heritage edition
Engine: LT-1
Axle/Gears: 3.08 posi
Hey everyone, I have a problem a year ago I installed my new top with glass window. I used the glue suggested for the installation but for some reason or another it has started coming up around the very back bow. Any suggestions for different type of glue? Unfortunately I don't remember what glue I used and have lost it since.
Old 01-07-2010, 11:51 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Convertible Top Glue?
I used 3M contact cement that I got at my local body shop
supply store.
Old 01-22-2010, 05:36 PM
JWKbride's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 305 H.O.
Yes, 3M contact cement...comes in a white tube, is translucent yellow and costs about $10 a tube. Once you glue with it the item needs to bond for at least 24 hours.
Old 01-22-2010, 08:50 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
when I put mine on I used weldwood contact cement works great. upholestry shop recommended it.
Old 01-24-2010, 05:04 PM
1REV1's Avatar
landau top glue is what's used.don't trim the back edge too much,let it go into the weatherstrip channel on one side and make sure the aluminum bow isn't oxidized ,flaking off the black top coat. glue is avail. in green and clear/yellow.3M stuff and reg. rubber cement isn't as good and dosn't hold up in wet conditions. we buy it from upholstery supply places like THE JOHNSON CO., MIAMI RUBBER,THREE RIVERS,ect... . if you need a top ask one of them for an EZ-ON TOP brand of tops,fit is always perfect and MADE IN THE U.S.A. SC. . good luck, NORTH JERSEY AUTO TOP AND UPHOLSTERY.
1992 Trans Am
05-10-2023 07:19 PM
69 Six Pack
10-05-2015 07:51 PM
yankeecarman
Convertibles
08-23-2015 07:47 AM
Dan Hubbard
08-12-2015 09:05 PM
Quick Reply: Convertible Top Glue?
