Electric Fuel pump shut off???
Old 12-15-2009, 11:10 AM
86IROC57L98's Avatar
Car: 1986 IROC-Z28
Engine: 5.7L L98
Transmission: 700R4 OD
Axle/Gears: B&W 3.27 Posi- :D
I've got an 86 iroc with a swapped carbed 350. It runs good, but i noticed that my fuel pump is always on whenever the key is in the on position. i have a fuel pressure regulator on it set at 4 psi, but abuddy of mine told me that it could have a shut off valve so it knows not to overflow the bowls in the carb. is this true, should it have like a shutoff valve or something? im not to intelligent on these types of subjects. Someone suggested that i put a switch in so i can shut it off at different times. all help is appreciated! thank you
Old 12-15-2009, 11:17 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Electric Fuel pump shut off???
Is it a factory carb. car, or did you put a carb on a fuel injection car?? is it overflowing bowls?? does car have a factory fuel return line?? what kind of fuel pump??
Old 12-15-2009, 11:29 AM
Car: 1986 IROC-Z28
Engine: 5.7L L98
my car was originally fuel injected (not sure of TBI or TPI) but it has an edelbrock 1406 600 cfm on it, with a puralator fuel pump (not sure of the GPH or PSI it does) and ive not seen a return line and would like to know more on that subject. i dont think the pump is hooked to a relay, just that the pump runs as long as the key is in "ON" position or running.
Old 12-15-2009, 02:55 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
if your car is before a tpi than you must have a return fuel regulator!
that means, a regulator with a return line for the pump!
i doing the swap and tested the fuel presure!
i using the mallory 4309 return style regulator!
i set my psi on 5 PSI for the holley double pumper
its not overflowing because the return regulator.
it is right that the fuel pump is on wen key is on
the fuel pumpted all the time around and the carb take the fuel he need!
the rest of the fuel go`s back to the tank because using a return regulator!
thats the way it must work for you!
but only if you using the original or aftermarket electric fuel pump
Dennis
Old 12-15-2009, 03:00 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
No you dont need a shut off valve. The way a regulator works is it restricts fuel flow to maintain a certain pressure. If the pressure builds up higher and higher eventually in theory the regulator will close off the outlet entirely so no more fuel can go through. This is where a problem comes in. If you have no return line and the regulator closes the fuel has no where to go. The fuel pump will continue to try anyways and will be overloaded. This will cause the pump to burn out prematurely.
Old 12-15-2009, 03:07 PM
Car: 1986 IROC-Z28
Engine: 5.7L L98
that sounds about right, but im not sure if i have a return line, and if so it wouldnt be hooked up that i know of. i know the main line comes into the engine bay, hooks up to a hose, runs through a fuel filter, then through the regulator and to the carb. Unless the other return line is further towards the tank than the engine bay, where would it start to branch off?
Old 12-15-2009, 03:09 PM
It should branch at the regulator itself
Old 12-15-2009, 03:56 PM
Car: 1986 IROC-Z28
Engine: 5.7L L98
would that be a fuel pressure regulator with a third nozzle or like a tee fitting right before it? cuz mine only has the 2 for fuel in and fuel out with a dial **** that you push in and turn anywhere from 1 - 5psi
Old 12-15-2009, 04:28 PM
Car: camaro iroc-z
you need the return style regulator
Mallory 4309-----------> Search this!!!
Old 12-15-2009, 04:46 PM
Car: 1986 IROC-Z28
Engine: 5.7L L98
is there a way i can substitue for a week till i can get one of those regulators?
Old 12-15-2009, 04:57 PM
In theory you could temporarily make a T before the regulator. However this isnt really a good solution as the t would hove to be the right size to allow a controlled bleed off of pressure while not being so much that it causes a pressure drop at the carb. Not really a good solution but i understand when a car is your daily driver things have to be done that are not ideal.
92camaroJoe
07-29-2023 07:57 PM
RazorN8
01-07-2022 11:44 AM
Glowsock
08-02-2020 07:36 PM
92camaroJoe
08-13-2015 06:07 AM
djmarch
08-09-2015 05:27 PM
Quick Reply: Electric Fuel pump shut off???
