Hella Headlight Conversion?
Old 12-13-2009, 11:56 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
http://www.summitracing.com/parts/HLA-003427291/
are these like....an H4 bulb conversion or what?
Old 12-13-2009, 12:27 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Hella Headlight Conversion?
kinda but ours are 4x6 i think
Old 12-13-2009, 02:13 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
nope i know for a fact that there 6 x 7...and i entered my car into the summit part finder =P
Old 12-13-2009, 02:15 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
those are great! get an h4 relay harness also. and some silverstar ultra bulbs from your local autozone.
Old 12-13-2009, 02:35 PM
Stephen's Avatar
Car: 87 GTA
#1, you have a Camaro. Yours are smaler
#2, the 92/92 'birds do use the smaller size, due to the different nose.
To the OP, I'd be skeptical. I've tried lamps like those & the light output sucked. Maybe those Hellas would be better, but I dunno. I'm just going to do a full HID conversion on mine.
Old 12-13-2009, 02:39 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
links? i saw the ones on carid.com for like $150...but with that kit id still have to buy the hella lamps..
Firebat's Avatar
From what I understand, the ones that say they are D.O.T. are nothing more than H4 conversions. The ones that are e-code/ece headlights have a slightly different shaped housing (but still fit) and project light from halogen bulbs better. Think of the e-codes as focusing the light better instead of scattered.
82-90 firebirds are 6x7, 91-92 are 4x6.
I have hella e-code 4x6's and they are very good quality, a lot better design than the ebay H4 conversions. I've had both. Haven't got a chance to try out the hella's yet.
Old 12-13-2009, 02:43 PM
Stephen's Avatar
Car: 87 GTA
In other threads about this, yes. But sorry, I'm not going to sit here & search for them, then post them for you. When you can just do the searches for yourself.....
itsMikey's Avatar
Engine: 5.7 350 TPI
http://www.carid.com/product.php?pro...t=86531&page=1
this ^^
plus the hella lamps??
good???
Old 12-17-2009, 07:32 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
bump?
Old 12-26-2009, 03:19 PM
racerx520's Avatar
how would these hella lights fair up against the HID conversions ive seen on Ebay? the $80 7x6 HID kit that is....
Old 12-26-2009, 06:24 PM
Stephen's Avatar
Car: 87 GTA
The Summit Racing link goes to a bare, empty housing. It is up to the buyer to decide what lamp to put inside it.
Old 12-26-2009, 11:41 PM
racerx520's Avatar
oh, i thought that it came with the conversion of some sort to wire it up to a H4 bulb. so it would kinda seem better to just go with the Ebay cheapo kit? cuz thats what im really starting to lean towards, that is if its a legit kit
Old 12-26-2009, 11:46 PM
Stephen's Avatar
Car: 87 GTA
Your not very likely to find a COMPLETE kit, of bulbs and housings.
Most likely, you'll need to buy the bulbs you want, then the housings that fit your car.
Buy those Hella's (if you want) then buy the bulbs separate. Either from Summit or elsewhere.
Old 12-27-2009, 12:27 AM
racerx520's Avatar
http://cgi.ebay.com/ebaymotors/HID-8...Q5fAccessories
says its all there. sounds like it too.
Old 12-27-2009, 12:34 AM
Stephen's Avatar
Car: 87 GTA
Go for it. When you get it in, let us know how well it actually lights up the road & get pics from the drivers position!
Old 02-28-2010, 12:13 PM
86Tran's Avatar
so would the 7x6 work? cuz theres a bunch of those
Old 02-28-2010, 12:18 PM
Car: 1986 IROC-Z28
those are the same fake ebay "projectors" with black reflectors. probably wont light up the road well since black isn't very good at reflecting light.
Old 02-28-2010, 12:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Hella E-Codes conversions are very good lamp housings. I have a set for my Camaro.
I think the only ones that are better are the Cibie E-Codes. I had Cibie conversions on my 2nd Gen.
BTW, why would someone install conversions and run Silverstars? There are better bulb choices out there.
I would fab up an upgraded headlight harness per the tech article here. For H4 bulbs, you'll also have to rewire the plug or buy a ready made conversion plug.
Linson
09-25-2021 07:55 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
Quick Reply: Hella Headlight Conversion?
