Does the GM Performance Parts basic Vortec 330HP 350ci have a timing tab?
Old 05-27-2001, 06:49 PM
Like a ROC 89's Avatar
Its the crate without the harmonic damper with it. I was looking at the pics of it and I cant see the timing tab on the timing chain cover....does it come with one? If it doesnt, how do you set the timing?
Old 05-27-2001, 08:11 PM
JPrevost's Avatar
Car: 91 Red Sled
Nope, unless you get the deluxe.
, Jon (350 TBI!)
91 Red My website
Old 05-27-2001, 08:29 PM
Since it doesn't come with the tab how do you set the timing?????????
Old 05-27-2001, 10:00 PM
rsilver's Avatar
No, you have to get an aftermarket one, I think from Mr gasket........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old 05-27-2001, 10:09 PM
So does it have to be in a specific spot or can you by any timing pointer undo one of the timing chain cover bolts and bolt the pointer on and it will be in the right spot? I thought that the position was specific to the engine? Or is it the damper that is specific? There are no special tools like degree wheels or the such to install the timing marker in the correct spot right?
midge54
12-27-2019 04:14 PM
Fast355
12-02-2016 06:33 PM
The_Phoenix
02-04-2016 07:10 AM
Mutillator
Exterior Parts for Sale
01-02-2016 06:44 PM
1nastygta
08-08-2015 07:38 PM
Quick Reply: Does the GM Performance Parts basic Vortec 330HP 350ci have a timing tab?
