Seafoam, good product but a word of caution
Old 05-09-2010, 10:56 AM
  #51
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
Re: Seafoam, good product but a word of caution
Originally Posted by kd5icr
Ok then. I have no choice I have to get a used engine because I just dont have the money to get a new one. Would you recomend that I use this in the engine. Now of course I get to hear the engine run before I get it, so I will have one that doesnt smoke or have a knock in it.
Up to you. If it's good used engine you shouldn't have any issues with it. If it has a bad gasket somewhere it could cause that gasket to leak. My mother-in-law's car developed a valve cover leak after I put it in. I ended up changing the cover gaskets and spark plugs cause it had around 110k miles and was still OEM. Was the gasket bad before? Probably leaked some or started to and the seaform just removed some grime around the leaking gasket. Did I get blamed for causing the leak by the mother-in-law? Of course!
Like anything use your best judgement. Seaform isn't going to magically fix major issues it's meant to be used cleaning more than anything else. I've heard of it cleaning sticky lifters and etc.
Old 05-09-2010, 11:05 AM
  #52
southbay08's Avatar
www.southbayfuelinjectors.com
Old 05-09-2010, 11:06 AM
  #53
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Oh I dont ever expect magic anything. The engine I get will be run for a while before I get it. I will not get worked over like the last 1 I got. I just see that a lot of people here like the stuff, so I just want to make sure you know, before I go and buy something. It is smart to always ask questions long before you buy anything. Saves on hassles I have been out of the car game for several years, products change and they came and go.
This is just my way of having piece of mind before I commit to getting anything. Be it a used part of anytype or a chemical to add to the engine in any way. Even having been a mechanic for 20 years it is always a good thing to ask when you just arent sure. After all the only dumb question is the one you didnt ask, right?
Old 05-09-2010, 11:09 AM
  #54
kd5icr's Avatar
Axle/Gears: Stock
Originally Posted by southbay08
Oh I agree also. If there is a leak it will be fixed. Even if that stuff shows it. I myself cant stand a leak on anything. As I said this is a CYA kind of thing.
Old 05-09-2010, 11:10 AM
  #55
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I've used Seafoam on all my cars. I never noticed a change, but I'm sure the stuff does what it's supposed to do....my cars were all running well when I used it, though. I have heard that it's a great product.
Old 05-09-2010, 05:47 PM
  #56
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
It does not smoke if put in the gas tank, only when poured into the intake...It does not take long for it to stop..In the old days we poured tranny fluid down the carb to clean the valves, and such...Don't know it if worked, but it sure as hell smoked alot.....
Old 05-09-2010, 06:14 PM
  #57
zachkuby87's Avatar
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
seafoam is awesome first time i ever used it i scared the hell outta myself after i sat there revving my car for 15 minutes until it stopped smoking i pulled out of the driveway stomped it to the floor spun out and almost had to buy the neighbor a new car i mean i expected it had to have helped after all that smoking but it literally felt like i doubled my power normally i could tank it and get some wheel spin chirp the tires but that time they just started spinning with ease....
Old 05-30-2010, 10:17 PM
  #58
southbay08's Avatar
just a test
Old 07-04-2010, 12:18 AM
  #59
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I had an issue with my new engine, the valve covers didnt have good baffles and it ended up pulling oil from the PCV into the intake, fouling plugs ect. Also started pinging after at WOT. I'm thinking this Seafoam might be just what I need to clean up my intake and valves/pistons of the oil/carbon.
Old 08-05-2010, 06:44 PM
  #60
snipzors's Avatar
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
i have an 87 tpi 305 and want to use seafoam but am unsure of where i can add it in, can someone get a picture and circle what vaccuum line i should pour it into?? THNX!!!
Old 08-05-2010, 10:05 PM
  #61
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Pull the vac line from the brake booster.
Old 08-05-2010, 11:37 PM
  #62
J.Prock's Avatar
I used to be a skeptic of seafoam but my cousin kept saying "Oh a dur dur dur put some seafoam in it" usually I replied with "F U" but I finally felt like trying it in my jeep and forr the first time since ive owned it the engine light turned off probably an emissions sensor that had carbon built up on it. YAY for seafoam!!!
Old 08-06-2010, 11:01 AM
  #63
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
seafoam stories are the most fun to tell...i had a 1980 GMC Jimmy (fullsize w/350) and it had not been started in 4 years. i started it up and got it warm, then put some C FOAM in the carb and BAM! instant throttle response (there was not much before) and then i went an pulled a 2000lb sand rail up a 60 degree dirt hill...it pulled it like a champ. dont forget..put it in ur mower and go carts if ya have any...it works
Old 08-28-2010, 08:27 PM
  #64
cjh1505's Avatar
Car: 1986 iroc z28
Engine: 5.0 f.i.
just put the seafoam in my tpi. holy crap the smoke that poured out!! i would make sure that your cooling system is up to par. my water temp shot thur the roof as i was pouring it in. i guess my car needed it cus she moves now!
Old 09-01-2010, 01:37 PM
  #65
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
When I try to get bikes running after they sit for a while I always put seafoam in the gas then get it to idle. After a 2 or 3 mile ride the carbs always clear up and it saves me a rebuild. Also when I used it on a ford tempo the amount of carbon and crap make the tail pipe shoot out black liquid. It is great stuff I love it.
Old 09-02-2010, 05:10 PM
  #66
alexdavis001's Avatar
Car: 1989 camaro
Engine: 383 roller
Transmission: 5-speed
Axle/Gears: posi 373
will this stuff hydro lock my motor if i cant getted stared again
Old 09-02-2010, 06:45 PM
  #67
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Axle/Gears: Australian 9 bolt 3.27 posi
i used sea foam yesterday on my 355 in my camaro. Put 1/3 of it in the carburetor until the engine coughed out, then placed the other 2/3 into a full tank of gas. When I fired it up it did smoke like a bugger but after a few minutes the smoke was gone and I can say the idle is definitely smoother and it does have a peppier response than before. Anyway I really liked this stuff and plan to use it again in the future.
onthedownlow
Old 09-02-2010, 08:17 PM
  #68
gmc2x94's Avatar
Car: '84 Camaro z-28
Engine: 400 sm
Transmission: undecided
Axle/Gears: 3.08 w/ eaton posi
Sea foam works great on any gas engine. You can even put it in the crank case, but be careful not to over fill your oil. I f you do this before your getting ready to drain your oil, it cleans out any small carbon and deposit that may form in the valleys. It also works great to clean the "varnish" in carbs when poured into the intake when running. I have used it for years. it works great.
Old 09-02-2010, 08:19 PM
  #69
midias's Avatar
It should not just wait about 15 minutes then push the gas pedal all the way down and start for EFI motors.
Old 09-20-2010, 10:13 PM
  #70
stielow775's Avatar
So i just had a clogged fuel filter will these seafoam help disolve some crap that is in my gas tank?
Anyone else have problems with clogged fuel filters its a 1992 z28 camaro.
Matt
Old 09-21-2010, 07:12 AM
  #71
Engine: 383 SBC
I imagine if you're clogging multiple fuel filters you have quite a bit of particles in your tank and it should be cleaned out. I've seen fuel pumps towards end of life eat themselves and that cause particles too.
If it's the first time it's clogged it's far easier just to change the fuel filter it takes about 15 minutes, the use of 2 wrenches, and doesn't leak out that much gas.
Old 09-21-2010, 07:47 AM
  #72
southbay08's Avatar
Matt
Hi Matt,
Although we provide a cleaning and flowtesting service, we also carry seafoam. It's a great product. We posted this info a while back, but here it is again. Hope it will answer your questions.
SEA FOAM MOTOR TREATMENT for Gas Engine Applications
100% Pure Petroleum
Use in All Engines in All Seasons
2 Cycle, 4 Cycle, and Diesels
Treats 3 Critical Areas: Gas Tank, Fuel Systems, and Crankcase
  • Cleans fuel injectors
  • Cleans carburetor jets
  • Cleans carbon
  • Stabilizes fuels
  • Upper cylinder lube
  • Removes moisture in fuel
  • De-icer
  • Frees sticky lifters
  • Frees sticky rings
  • Removes moisture in oil
  • Cleans P.C.V. systems
  • Cleans catalytic converter odors
  • Oxygen sensor safe
How Many Mechanics Use SEA FOAM
In Tune-Up of 4 Cycle Gasoline Carbureted or Fuel Injected Engines
Autos, Trucks, and Tractors
  1. With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
  2. Pour 1/3 to 1/2 pint into oil crank case to clean rings, lifters, dirty parts and remove moisture.
  3. Pour 1/3 to 1 full pint into fuel tank to clean injectors, carburetor jets, fuel lines and remove moisture.
  4. Immediate Results: Smoother idle, increased R.P.M.’s better throttle response and improved performance. See label on can for detailed results for use in each area.
FUEL TANK, CARBURETOR, INJECTION and OIL CRANKCASE.
For Peak Performance, Use SEA FOAM Every 2,000 to 5,000 Miles
  • A 100% pure petroleum product for use in all gasoline and diesel type engines, both 2 and 4 cycle. OXYGEN SENSOR SAFE.
  • Cleans dirty engine parts internally by removing harmful gums, varnish and carbon. WORKS AND PERFORMS INSTANTLY.
  • Removes moisture from oil crankcases and fuel tanks.
  • Stabilizes and conditions fuels. Use for engine storage.
  • Cure hesitations, stalls, pings and rough idle due to carbon buildup.
  • Helps pass emissions test. EPA Registered.
When Used Thru Injection or Carburetor
  • Cleans carbon build up
  • Cleans intake valves and pistons
  • Gives smoother idle
  • Cures hesitations and pings
  • Restores power and pickup
  • With warm engine running, SLOWLY poor 1/2 pint through carburator, throttle body or direct manifold vacuum line that will feed ALL CYLINDERS. Possible sources are P.C.V. valve or brake booster line. Turn ignition off. Restart engine after 5 minutes. Be sure exhaust is well ventilated. Fumes will be extreme for a short period of time.
  • For use in injector cleaning machines, use 50% SEA FOAM and 50% fuel.
  • Fill diesel filters with SEA FOAM to clean injectors fast.
When Added to Crankcase (Oil)
  1. Frees sticky lifters and rings
  2. Increases R.P.M.’s vacuum and compression
  3. Cleans dirty parts
  4. Removes moisture
  5. Cleans PCV valve systems
One pint treats 10 quarts of oil (avg. 1 1/2 ounce per quart).
When Added to Fuel Tank
  • Cleans fuel injectors and carburetor jets
  • Cleans carbon as you drive
  • Lubricates upper cylinders
  • De-ices and removes moisture
  • Diesel full conditioner and anti gel
  • Stabilizes fuel
One pint treats 8-25 gallons of fuel (average 1 ounce per gallon).
In Injector Cleaning Machines
Add a 50/50 blend of fuel and SEA FOAM into injector cleaning machine. Run directly through the fuel rails to clean injectors fast. Add SEA FOAM to your fuel tank to clean injectors as you drive.
For more information, call 516-492-6504
Old 09-21-2010, 08:02 AM
  #73
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
If you have a clogged filter just change it out. When you have the new one in place then add some sea foam or other fuel system cleaner to it.
I seafoamed my daily driver S10 (1/2 through the brake booster line, 1/2 in the gas tank) and it did smoke ALOT for a few minutes then let up. However a week later I had to replace the intake gaskets, they probably were not in the best shape before the seafoam since they were original with about 160K on them at the time. I have not used anymore since, just some Lucas tune-up in a bottle seems to keep it running like new. The truck currently is two oil changes away from 200k so I may seafoam it again in the near furture, I just hope I dont have to replace anymore gaskets this time (like the original head gaskets)
Old 09-21-2010, 12:02 PM
  #74
awolfalone2006's Avatar
Car: 88 sport coupe
Engine: 2.8
Transmission: auto
I guess I haven't paid very good attention, didn't know my thread was this popular.
Old 09-25-2010, 05:26 PM
  #75
stielow775's Avatar
I put some seafoam in late last night let it sit all night fired it up this morning, I always thought it was snake oil. It was on a 92 z28 that had a bad egr valve. Let me just say do this at night as for about 15-20 minutes it looked like smokey the bandit was on patrol.
Car is way more peppy, pinging less, and I will be a lifetime user of it.
Definitely works.
Matt
Old 09-25-2010, 05:36 PM
  #76
southbay08's Avatar
We like Seafoam and Techron. They are reputable. Techron is from Chevron, and
Seafoam is EPA registered!
Old 09-26-2010, 12:58 PM
  #77
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Definitely works.
Matt
no seafoam is about as good as it gets...Have used it many times, after a friend told me about it...
Old 09-28-2010, 09:42 AM
  #78
92Firebug's Avatar
dont forget to put some in your oil 100 miles before your next oil change! it will make a difference
Old 10-01-2010, 05:03 PM
  #79
FloridaRS91's Avatar
what about that seafoam trans tune? that any good?
Old 10-03-2010, 04:41 PM
  #80
92Firebug's Avatar
i wouldnt doubt it.
Old 08-20-2011, 01:09 AM
  #81
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Old thread. But if one has a head gasket leak, would sea foam clean it out. I wouldn't think so. But thought id ask.
Old 08-20-2011, 06:38 AM
  #82
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
No. That sounds like trouble brewing IMHO.
Old 08-20-2011, 08:03 AM
  #83
Engine: 383 SBC
It may clean oil in upper intake. It's not going to fix your headgasket because it's not a sealer or stop leak.
Old 08-20-2011, 09:28 AM
  #84
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I use seafoam in all my small engines as well.....mower, snowblower, trimmers, etc.......pour some in the gas tank before your last run of the season and watch all that crud burn off......they all start right up......neighbors are jealous cause I never have a problem
Old 08-20-2011, 11:31 AM
  #85
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
It's a good product and works well doing what it is supposed to do but it isn't a fix all.
Old 08-20-2011, 11:35 AM
  #86
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I don't want it to seal or fix it. I am hoping that if I have a small leak that sea foam won't clean it out.
Old 08-20-2011, 12:18 PM
  #87
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
I was sceptical of this project when my friend told me about it. I am glad I saw this, I'm def. going to use this now.
Old 08-20-2011, 07:06 PM
  #88
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Originally Posted by 91project
Hey guys, seafoam is great, but if you go to an NTB, Merchants, Firestone,MR.Tire, Sears, ECT. the 3 step fuel system cleaner is the same thing, at work we take the vacuum line off of the brake booster and run an iv into it, the iv is the best way to do it, and i dont really recomend it on OBD2(96+) unless you are replacing the o2 sensors, and it will not hurt any other sensor
If introducing any liquid to a running engine via a vaccum line make sure its small, unless u are using something to step the size of the booster line down it's likely it will pull way too much into the engine at once causing hydrolock and could possibly bend rod(s)
Old 08-23-2011, 05:52 PM
  #89
thomas707's Avatar
Car: 1989 RS Camaro
Transmission: TH700R
Axle/Gears: No posi YET!
This crap clogged my c/converter from 22yrs of engine gunk or carbon build up lol couldn't even see through it I guess it did it's job but word of caution will clog some **** pardon my French
Old 08-24-2011, 02:43 PM
  #90
eagleks's Avatar
Just a comment... a bit more costly, but well well worth the money is BG Products.
It adds to the gas, and will clean everything better than anything I've ever seen.
My car would hardly run at one point due to clogged injectors, it ran like it was new once I used the BG cleaner thru the gas.
Typically found at shops and possibly some car parts shops, or can be ordered.
Old 08-26-2011, 12:23 AM
  #91
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
58 mark asked and didnt get an answer that i saw, anyway how do you put it in a 2.8 well anyway where i know the gas tank and brake booster (master cylinder?) but where else?
Old 08-26-2011, 03:27 AM
  #92
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Will definatley be running a can of this through my GTA either today or tomorrow for a good smoke show. I'll be sure to take a video for you guys.
Old 08-26-2011, 05:58 AM
  #93
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Same way as the V8's. Brake booster vacuum line, and/or through the gas tank.
Old 08-26-2011, 02:27 PM
  #94
eagleks's Avatar
Seafoam is fine for that occassional cleaning, etc.
But, if you want to really clean out the system, .... use the BG Products. There is a vast difference.
Old 08-26-2011, 04:42 PM
  #95
kmcn47's Avatar
Transmission: 5spd
cool thanks and nice camaro by the way
Old 08-26-2011, 07:12 PM
  #96
ronnoco67's Avatar
Car: 91 RS vert
I can't wait to try this stuff, I've always seen it, but I thought it was"snake oil" too. My Camaro had sat for 2-3 years when I bought it and I had to replace the fuel pump to get her going. Interested to see how Sea Foam may improve it's performance.
Old 08-26-2011, 08:38 PM
  #97
southbay08's Avatar
Since this thread has been receiving so much action, thought I would repost info that i included on this thread back in March 2010.
Seafoam:
100% Pure Petroleum
Cleans carbon
Stabilizes fuels
Upper cylinder lube
De-icer
Frees sticky rings
Oxygen sensor safe
Gives smoother idle
Cleans dirty parts
Removes moisture
Stabilizes fuel
516-492-6504
http://southbayfuelinjectors.com
Old 08-27-2011, 02:44 AM
  #98
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
I put sea foam in my oil and i put it away for winter and now it smokes every time i start it.
Old 09-29-2011, 10:55 PM
  #99
skully-bones 13's Avatar
Car: 1985 Camaro IROC-Z
Engine: 305 w/ 4 barrel carb
Transmission: brand new 700r4
about a month and a few days ago, when i was still debating on selling my 1994 ford 4x4, me and 2 of my friends were in my yard and had 5 cans of seafoam hehehe, i did the vaccume line on my 5.0, my friend did his vaccume line on his 5.8 in the bronco, then my other friend did his vaccumes in his f250 with the 460. hehehe, dear god.. me being in a residential area with a field on the right and neighbors on the remaining sides, and all of our trucks having longtubes headers and glasspacks, magnaflow, and thrush, all cranked at the same time and smoked out the neighborhood, hahaha my neighbores came out and asked if there was a fire
Old 09-30-2011, 12:39 PM
  #100
Thirdgenlove's Avatar
Car: 1989 Trans Am GTA
Engine: 350 Tpi rebuilt
Hahahaha that sounds like a party. Well after reading this I'm gonna be doing a tune up here soon on my camaro and I'm definitely gonna try the stuff. My car always feels likeke it's bogging down so hopefully this will help
Quick Reply: Seafoam, good product but a word of caution
