Ignition switch starter wire
Old 11-24-2009, 04:00 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
What exactly does it do to the starter?
My car has up and decided it wont crank and I dont feel like dealing with it. (It's not VATS) I'd rather just bypass the whole thing and have a pushbutton start but Im not sure what to wire to the starter. Does it complete the circuit to ground or apply 12v or what?
Old 11-24-2009, 08:13 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Re: Ignition switch starter wire
thats what happen to mine my ignition went out and didnt wanna crank over so what i did was....just run the negative from the starter and get ur power from the fuse box and it should start right up...just use a test light to see what is power and what is negative....and run a wire from the radio fuse to the switch and connect the negative
Old 11-25-2009, 01:31 AM
Car: 1992 Camaro RS
Im not quite sure I follow what you're saying? The negative Im going to assume is the small purple wire by itself that goes to the ignition switch. I need to connect that to the fuse box, but you said to connect it to a negative... I think. Thats simple enough, but what's the deal with the wire friom the radio fuse? What's that supposed to do?
Also, I've been looking at this diagram since Im tired of my heatsoak issues also.
If I ran the wire straight from that positive terminal on the remote solenoid to a push button start and then to the S terminal, would I have problems turning the car off? The key switch is still in control of the ignition, right?
Old 11-25-2009, 07:02 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You shouldn't have to resort to a remote solenoid. If you're starter is suffering from heat soak, it's likely just near the end of its life. A much better solution is to install a later style starter from an LT1. If funds are an issue a replacement starter to match existing is around $50. If funds are extremely low a replacement set of brushes for your starter runs around $3.
If the issue is the power going to the solenoid the ignition switch is the most likely culprit. If the switch is going bad, bypassing the starter solenoid power from it isn't a good fix. This switch also controls the power to the fuse panel under the dash. If it's bad to the ignition then it's likely bad, or going bad, to the panel.
When it doesn't want to crank-no click, no turn, nothing-run a jumper wire to the S terminal on the starter. Jump this wire to the positive terminal. IF your battery is GOOD the starter should turn over. If it spins with it jumped out you'll know the problem is in the ignition circuit to the S terminal. If it doesn't (and you know the battery and the positive cable to the starter motor is good-starter getting 12+ volts) then you'll know the starter itself is bad.
88bullet (09-15-2019)
Old 11-27-2009, 04:19 PM
Engine: 350 tpi
well on mine i ran it to the fuse box to get the power...and the car only starts when the key is turned in the on position cause it only has power when the power to that fuse is on....or u can just run both power and negative from starter into the car.....and put them to the push button and do it that way...but i did it with the fuse so it only starts if the key is in the on position..
Old 11-27-2009, 05:30 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
no cranking can me a couple other things, such as a bad starter or a locked engine, test for power at the S terminal when the key is turned to start,
Old 11-28-2009, 07:32 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
$70
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories
Old 11-28-2009, 07:38 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If you are doing any wiring in a car you NEVER touch the negative.Negative is the return path of a circuit through the block / frame back to the battery.
If you have the radio fuse hooked up to negative ;every time you push the switch,the fuse would blow because it is a direct short to ground
Test it ;Put a wire on the batt neg terminal and touch to frame?
Then try it with the pos terminal and see what happens; sparks
Negative terminal is DEAD unless someone has put battery in backwards
Old 11-28-2009, 07:47 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by InfernalVortex
What exactly does it do to the starter? Does it complete the circuit to ground or apply 12v or what?
Starter power goes;
Batt +> ign switch >safety switch > starter solenoid> ground (negative) through the starter body
Old 11-28-2009, 01:40 PM
Engine: 350 tpi
sorry hes right i got mixed up...your going to run the wires from the power of the starter and the switch terminal and those go to ur switch and that should fire it right up....
Old 11-30-2009, 06:26 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
run the wires from the power of the starter and the switch terminal and those go to ur switch ....
Much easier to follow circuit if you think of it as the power goes TO the starter , not from it
Batt + > switch> starter
BRoss99
12-07-2020 06:50 PM
89GTAOz
05-16-2020 09:31 AM
Caspar
06-19-2016 11:19 PM
Bryan F
08-18-2015 02:28 PM
djmarch
08-09-2015 05:27 PM
Quick Reply: Ignition switch starter wire
