pulling rocker arm studs
Old 11-24-2009, 03:50 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
so i bought this tool from summit. they were out of the one i was used to, but the parts guy said itll work too. the heads im trying to use it on are vortec. this is the tool im using http://www.summitracing.com/parts/SUM-900136/ im wondering if any of you guys have any experience using it? i need to pull the studs out on my heads and have drilled in studs put in for my 383 im building
Old 11-24-2009, 03:58 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: pulling rocker arm studs
I have ben doing some reserch and came across this. Let me know how you got them out.
http://www.maxchevy.com/tech/2007/ii_12-stud-1.html
https://www.thirdgen.org/forums/tech...ow-if-arp.html
https://www.thirdgen.org/forums/tech...ers-studs.html
Old 11-24-2009, 04:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Rocker studs will pull out with hi lift cams which is why people change to screw in ones.
You can just stack big nuts and a washer on them and crank them out with a non locking nut
Old 11-24-2009, 04:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, I made a tool similar to that, out of 1" square CRS, with 4 holes in it so that I could do 4 at a time. It guides the tap, and gives you some height too. Use a long handle ratchet, and grade 8 3/8"NF nuts (not stock style locking nuts, that just tires your arm out faster).
Remember, pull ONE out, and tap it's hole, then move on. If you pull ALL out, then go back and want to align your tap, you'll see why that's bad
db057
09-04-2015 07:57 AM
SLNTSCPE
08-22-2015 09:15 PM
Zeek1041
Theoretical and Street Racing
08-21-2015 08:45 PM
Cameeeero
08-20-2015 03:06 AM
Quick Reply: pulling rocker arm studs
