Spark Plug Non-Fouler Inquiry
Old 11-19-2009, 07:47 PM
GeneL's Avatar
Car: 1983 Camaro Sport Coupe, T-Top
Engine: LG4 5-Liter V8, 305cid
Transmission: NWC-T5 Manual 5-speed
Axle/Gears: GU5 Axle Ratio 3.23 Rear
Hey guys and gals,
Ok, so yesterday I had my car tuned after it began to run kinda rough last week and my mechanic found that the #8 plug was fouled enough to probably be the cause and explained reasons that this in itself could cause the problem, with the ultimate solution of course being relatively costly major engine work.
But, he did give me an alternative solution, abeit not a permanent fix, that might keep me on the road for a while longer...that being a Spark Plug Non-fouler.
I gave him the go-ahead to install it (added $9.95 to the final tune-up cost) and he completed the tune-up and the car is running great.
So, I'm curious what you all think about this small modification, how effective it is, how long can I expect the plug to remain "unfouled" and, if there are any down-sides to using one of these gizmos?
Thanks,
Gene
Old 11-22-2009, 09:17 AM
SSC
SSC's Avatar
Car: No more birdy
Re: Spark Plug Non-Fouler Inquiry
Ahh hmm.... Yeah they work for a short time to those who dont know what this is its a little tube that extends the spark plug out of the head kinda cheezy. Did the mechanic mention why the plug was fouling? Not to be harsh or anything but chances are good the plug fouling was due to a worn plug or a crappy plug wire. If the rings are bad in that hole or you have a valve sucking oil the anti plug fouler isnt going to do anything for it may keep it a little cleaner for a day at most compared to where it should be.
Old 10-01-2011, 05:39 PM
3rdGenMess's Avatar
Car: 1990 RS
Engine: SBC 350 YearOne Crate
Transmission: T56 (LT1)
Well I guess im having the same issue...I put new plugs in and got maybe 5-10 seconds of idle, pretty much the POS didn't even warm up!!! Im getting so pissed at this car...the front plugs on both sides are fine but the futher I go back the blacker they get..hell the 4 in the back near the distributor look like charcoal briquettes...I leaned my carb all the way out before starting and it still fouled them after on start...could it be oil or wires somebody help me please before I hurt myself trying to figure this out
Old 10-01-2011, 06:07 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
what kinda carb is it? do the 4 bad plugs smell like gas?
Old 10-01-2011, 06:54 PM
3rdGenMess's Avatar
Car: 1990 RS
Its a holley 750 vacuum secondary street avenger....as far as the plugs go, I don't know wether they smelt like gas or oil smh...I think I have a oil leak but don't know if its the gas half burnt
Old 10-01-2011, 07:33 PM
3rdGenMess's Avatar
Car: 1990 RS
Old 10-02-2011, 06:02 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
have you tried adjusting your float level on the bowls? maybe the rear is flooding?
Old 10-02-2011, 06:07 AM
3rdGenMess's Avatar
Car: 1990 RS
Wouldnt the front flood too?
Old 10-02-2011, 06:25 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
not neccesarily. they are seperate from each other. you should be useing a fuel pressure regulater before the carb, set around 5 psi. a gauge to verify the pressure is good too. i have a gauge right on the dual feed line. what are you useing for a fuelpump?
Old 10-02-2011, 06:29 AM
3rdGenMess's Avatar
Car: 1990 RS
Im using a mechanical fuel pump...I have a intank fuel pump hooked up but I think its dead now as well...so im not even going to bother trying to fix it...jus run mechanical. My secondary float is overflowing but wont the air/ fuel mixture screws stop it from pouring too much? These are probably some dumb questions but I never touched a crab before in my life lol
Old 10-02-2011, 06:34 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
its cool. no, your gonna need to adjust your floats. at least it wont cost you anything. lol.
Old 10-02-2011, 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds to me like you need to adjust the floats, which is very easy. Do a net search or check the following link for how-to info:
http://hotrodscott.blogspot.com/2007...ingtuning.html
JamesC
Old 10-02-2011, 06:51 AM
3rdGenMess's Avatar
Car: 1990 RS
Very true indeed and that's definitely the road I need to be on costless repairs, do you think I should regulate it as well to be on the safe side???
Old 10-02-2011, 06:54 AM
3rdGenMess's Avatar
Car: 1990 RS
I have an idea on how to adjust them only thing is do you think my crusty black sparks will fire long enough to make adjustments
Old 10-02-2011, 06:57 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i use regulater for consistent fuel pressure. but you can get by without one for now as long as your only useing the mechanical pump. it doesnt take long to adjust the floats. do you have the clear sight plugs?
Old 10-02-2011, 07:10 AM
3rdGenMess's Avatar
Car: 1990 RS
No I have the non sight screw in sights..who makes "sight" plugs you can't see thru the irony...which brings me to this...is the rule of thumb concerning the fuel sights pliable? If its anywhere above the bottom of the sight its garaunteed to flood or can it be pushed a bit...to be honest I haven't completely taken them out cause fuel comes out pretty fast on the rear and is more then leaking out the front smh I think I jus asnwered my own question
Old 10-02-2011, 07:25 AM
JamesC's Avatar
You also might wish to take a peek at the Holley tuning sticky in the carb forum.
JamesC
Old 10-02-2011, 07:26 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
thats a good link james put up there. any speed shop should carry clear sight plugs, but you dont NEED them. im sure holley has a bunch of info on theyre site as well. its gonna be night & day difference when you get the carb set up & tuned correctly.
Old 10-02-2011, 07:35 AM
3rdGenMess's Avatar
Car: 1990 RS
JamesC
You talking about This link here??? Yes, I think i seen all I needed in the first paragraph ima cont. Reading tho...im on barracks watch so ima see what im not doing and hopefully ill be back giving you guys tracking numbers for y'all superhero capes
Old 10-02-2011, 03:09 PM
3rdGenMess's Avatar
Car: 1990 RS
Well I started my tuning proceedure...went to turn over the engine a big spark shot out the carb....idk if I went from bad to worse or what smh...clueless!
Old 10-04-2011, 07:40 PM
3rdGenMess's Avatar
Car: 1990 RS
LOL ok here's the update on my spark issue...well I called myself being a good consumer and call a "Mobile Mechanic" long story short this SPOS come to my house and don't know the first thing about a damn carb even if Dr Suess wrote a book about it...my carb shot a big *** flame out the top and he said ahhh yea its too much fuel...he was 5 seconds from picking his teeth and tongue out of my garage...kicked his *** out and told him to find his way out the neighborhood lol...yea that maybe harsh but I can imagine how many ppl this guy ripped off by now...but I'm back it myself hopefully headed in the right direction I think I have a timing issue :s...
Old 10-08-2011, 04:22 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
lol. yea, i think id time the motor first.
Old 10-08-2011, 08:11 AM
3rdGenMess's Avatar
Car: 1990 RS
Yea Joe I finally got the time right and went to turn it over and it still didn't start...good thing is the backfire is gone bad thing is I don't know why it ain't starting, got fuel, air, and combustion even used starter fluid and still can't get it to turn over...I got spark but do you think its possible my dizzy coil is not putting out enough power...I don't have a multimetere but this seems like it could be the issue
Old 10-10-2011, 02:51 PM
3rdGenMess's Avatar
Car: 1990 RS
Still having issues...I checked everything....things I've notice but don't think they would stop the engine from starting...half my spark plug wires are cracked, my distributer rotor cap, the silve prong the ignition coil sits on is slightly bent...I got new wires and plugs, I just want to know before I put them on that the plugs and wires were the issue
Old 10-10-2011, 03:02 PM
3rdGenMess's Avatar
Car: 1990 RS
Wait!!! Do you think the car being on jackstands could cause the fuel to not get to the front pistons and flood the rear pistons making starting impossible??? I'm looking at the engine and its tilted backwards a bit...when my electric fuel pump was connected it fired right up...I'm guessing because it primed the system and all the cylinders were ready to ignite...but for some reason its not working anymore and that's all can pretty much bring this back to...somebody help I think wee almost there!!!
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
db057
04-28-2019 07:45 AM
Jlanz55
09-09-2015 09:09 AM
90formulaVortec
09-08-2015 12:42 AM
89 formula TPI
09-07-2015 11:06 AM
Quick Reply: Spark Plug Non-Fouler Inquiry
