T5 spline count?
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
T5 spline count?
I thought the 4th gen V6 5 speeds were a different spline count than V8?
Saw this ad on craigslist, ad describes v6 5speed being parted out, 4th gen, however the trans appears to look identical to what would be in a v8 powered thirdgen?
http://nh.craigslist.org/pts/1467504223.html
-- Joe
-- Joe
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T5 spline count?
It's the bellhousing and input length that make's it incompatible.. The 4thgen V6 trans uses a Ford bolt pattern.
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Ford Bolt pattern?? The 3.4l v6 trans are the same as the third gen v8 trans except for the input shaft length and gear ratio, the v6 has about 1/8 inch more length to it. It probably could be made to work. now the newer trans from the 3.8l are completely different.
I forget about those early 93-94 v6s.. (yes, I didn't read the craiglist ad, just saw the post asking about 4thgen V6s)
Prodigious
09-18-2015 05:23 AM
