BRAKE light on dash won't turn off
Old 11-05-2009, 03:14 PM
IROC-Zach28's Avatar
Car: 87 IROC-Z
Engine: 5.7 350 TPI
Don't know how it happened, but I can't figure out how to shut it off. My emergency brake is not hooked up (a little dangerous, I know). I am not very electric-savvy so any suggestions would be appreciated.
Old 11-05-2009, 04:03 PM
NINÅ's Avatar
Car: LOWERED ♦ CRIMSON METALFLAKE
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Broke Light
If the feel of the hydraulic brakes is OK then one of the switches might be closed position when it should be open.
Take a look at the parking brake switch first because it’s easier to get to.
If it’s OK you can disconnect the wire to the hydraulic warning switch and see if the light goes out. Don’t forget to reconnect it when you’re finished.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old 11-05-2009, 05:06 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: BRAKE light on dash won't turn off
When the parking brake light comes on without the parking brake it is a signal of pad wear or brake problems. This is per the original owners manual.
Old 11-05-2009, 05:44 PM
polaris91's Avatar
Car: 88 camaro z28
also check to see if your brakefluid is low
Old 11-05-2009, 06:19 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
there should be a sensor on the prop valve, you'll see it under the brake fluid reservoir, check to make sure that wire/sensor isn't loose
Old 11-05-2009, 08:29 PM
Car: 87 IROC-Z
Engine: 5.7 350 TPI
Thanks guys, I will see what I can do to figure it out. I just replaced the power booster not too long ago, but when I press down on the brake pedal it doesn't feel like the pressure is high enough. I admit that it stops better though when I get the pedal down.
Oh and also, the light had shut off for a few days, but then came back on. ???
Old 11-05-2009, 09:08 PM
HCR13's Avatar
Car: 1987 Trans Am
sounds like it could be something loose...
Old 11-06-2009, 07:43 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The switch on the prop valve will ground when there is bias front to rear in the hydraulic system. If you disconnect the wire and the light goes out, reconnect it and the lamp lights and check continuity to ground at the wire connector then the lamp is doing as it should and warning you of a hydraulic problem in your system. Either air is trapped or fluid is leaking after the prop valve.
When you replaced the booster was there any chance that the master ran low on fluid? Is it low now?
Old 11-06-2009, 02:56 PM
Car: 87 IROC-Z
Engine: 5.7 350 TPI
There is plenty of fluid. Where is the wire located?
Old 11-06-2009, 03:00 PM
naf
naf's Avatar
The brake sensor wire is attached to the center of the prop valve, directly underneath the MC.
Vintageracer
01-10-2020 05:33 PM
zeitghaist
08-18-2015 07:33 AM
tnrednneck
08-13-2015 08:57 AM
Omega
08-10-2015 12:46 PM
BrianI
08-09-2015 11:52 AM
Quick Reply: BRAKE light on dash won't turn off
