T-5 V6 to V8 conversion kits???
Old 11-03-2009, 12:10 PM
Pyronight's Avatar
Car: 91 firebird/68 Camaro
Engine: 3.1L V6/Ram jet 350 crate
Transmission: T-5/L60E
Axle/Gears: 7.5 10 Bolt/3.90 posi
I am dropping in a 350 and heard about a T-5 conversion kit that takes it from a V6 to V8. Is there any truth to this rumor and if so would it be worth it? Also would it stand up to the additional torque from the V8? Or should I just get a T-56 and be done with it?
Old 11-04-2009, 04:56 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: T-5 V6 to V8 conversion kits???
Its possible, you would need a v8 bellhousing and a v6 clutch. but IMO it wouldn't be worth it because the 10 spline input of the v6 trans wouldn't hold up to the power of the 350. Even the V8 t-5 are not reputable for holding up well to the power and torque of a 350.
Old 11-04-2009, 05:19 PM
Pyronight's Avatar
What do you suggest I do then as I have everything I need EXCEPT the trans?? I have the old t-5 from my v6 but REFUSE to go back to a automatic. never again will I deal with an auto
Old 11-04-2009, 08:35 PM
Engine: 350TPI/ S50
I Would suggest at the very least find a v8 T-5, World Class if possible. Or if you you have the money just go to a T56 and not haveto worry about breaking.
Old 11-04-2009, 11:11 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i got my facts wrong ealier, its 14 spline for v6, 26 for v8, 10 spline for mustang. sorrry.
Old 11-06-2009, 10:12 AM
Granny's Avatar
Speedway Motors sells a 1" x 14 spline clutch disc that's 10-1/2" dia, PN# 910-15649 for $69.99. There is also the Advance Adapters disc that Summit sells, PN# ADD-716104 for $117.95 (might be an old price)
Input shafts on the V8 T5 and the V6 T5 both neck down to the same dia, so i doubt that the V8 input is much stronger than the V6 version. Gear ratios are different, but that works for some. Lower 1st gear ratios can really wake up a car w/ mileage freindly rear gears.
Old 11-06-2009, 10:23 AM
Pyronight's Avatar
[quote=Granny;4337568]Speedway Motors sells a 1" x 14 spline clutch disc that's 10-1/2" dia, PN# 910-15649 for $69.99. There is also the Advance Adapters disc that Summit sells, PN# ADD-716104 for $117.95 (might be an old price)
So if I combine the spline clutch disk with the adapter disc from summit it should hold up for a while? I checked out the spline clutch disk and it says it for a ford, does that matter or not really?
Old 11-06-2009, 10:49 AM
Granny's Avatar
It says ford in the Speedway catalog because they use the disc to fit a V6 T5 behind a flathead.
It's a complete 10-1/2" clutch disc w/ 1" x 14 spline hub. fits the T5 input shaft and a normal 10-1/2" pressure plate. All you need is...
...V8 T5 bellhousing
...Speedway disc
...slight trimming of V6 input shaft's pilot length (usually too long)
...may need to machine down the outer dia of the V6 T5's front bearing retainer to fit the pilot dia of the V8 bellhousing (quick 5 min job at a machine shop, or you can send it to me and i'll do it for free, just the cost of return shipping)
PurelyPMD
05-05-2016 04:57 PM
CamaroX84
07-04-2001 12:47 AM
vortech305
04-17-2001 01:42 PM
1984 Z28 BlackGold
09-29-2000 02:00 PM
GlenYappa
08-01-2000 01:18 PM
Quick Reply: T-5 V6 to V8 conversion kits???
